Results 1 to 8 of 8
Thread: Moving toolbars in ACAD Map 2006
    2005-11
    Hawaii
    3
    Angry Moving toolbars in ACAD Map 2006
    I can't get my toolbars to stay where I put them in AutoCAD Map 2006. Each time I exit, then open Map again, the toolbars are back to where they started. Also, it seems that when I customize toolbar buttons, they don't appear until I've exited and reopened Map.
    2001-03
    13,499
    Default Re: Moving toolbars in ACAD Map 2006
    Hi
    Please note I have *moved* this thread from the AutoCAD Customization forum to this one...
    Why? - As you are using an AutoCAD 2006 based product, the issue / problem you are currently experiencing is related to the new CUI interface / functionality.
    Thanks, Mike
    Forum Moderator
    2001-03
    13,499
    Hi
    For starters have a browse of the following threads...
    Toolbar position
    Notes on the philosophy of CUI
    Have a good one, Mike
    2005-11
    Hawaii
    3
    Quote Originally Posted by Mike.Perry
    Hi
    Toolbar position
    Thanks, Mike!
    I checked out the threads you suggested, but none of them address my problem, although "Notes on the philosophy of CUI" will require more reading.
    I'm upgrading from Land Desktop 3, Civil, Survey to Land Desktop 2006 and Civil 3D 2006. Toolbars seem to behave themselves in those applications. It's in Map that I am having this problem. I am new to CUIs and have read as much of the help and instructions as I can find, as well as downloading the videos from ADesk. It's gotten to the point where any help I get is just restating what I've already read...
    2001-03
    13,499
    Question Re: Moving toolbars in ACAD Map 2006
    Quote Originally Posted by cgarland.javanet
    Hi
    I take it, the LockUI command or using a Workspace, from thread "Toolbar position" did not work for you.
    I take it, using a Workspace, from thread "Notes on the philosophy of CUI" did not work for you.
    2005-11
    Hawaii
    3
    That's correct. Land Desktop seems to work OK, but the problem seems to occur when I'm using "Land-enabled Map". I've been using the LOCKUI command through the right-click and the toolbars and I think I'm understanding CUI customization, although I need more practice. But there's either something I'm missing or there's something in the program that's not set right.
    Thanks for the interest
    2001-03
    13,499
    Hi
    Very strange...
    Hopefully a Map 3D 2006 person will read this thread and chime in.
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,825
    I have heard reports of some verticals not acting correctly if the core cui is not the main cui file. In my experience, with ABS, this hasn't been the case. I have ABS.cui partial to my enterprise cui file. However. I have customized toolbar visibilty or position to this date.
    I have noted in other posts that sometimes changing the load order of the partials helps. Just drag-n-drop the partials into the desired order. Once again, I haven't done this personally.
  1. Moving Toolbars
    By jcronburg in forum ACA General
    Last Post: 2007-01-29, 12:39 PM
  2. Toolbars moving in AutoCAD 2006
    By nickeshaffer in forum AutoCAD General
    Last Post: 2006-03-22, 01:49 AM
  3. moving toolbars
    By mlwill in forum AutoCAD General
    Last Post: 2005-01-04, 08:18 PM
  4. 2005-My toolbars keep moving around
    By demilio in forum AutoCAD General
    Last Post: 2004-08-26, 01:22 PM
  5. Toolbars keep moving around
    By LanceMcHatton in forum AutoCAD General
    Last Post: 2004-06-04, 05:46 PM
