Results 1 to 6 of 6
Thread: Archectural floor plan to single line schematic
    100 Club charlie.bauer341340's Avatar
    2002-05
    Here, because I'm not all there
    141
    Question Archectural floor plan to single line schematic
    I have been tasked with taking a floor plan and converting it to a single line drawing, complete with extractable coordinated for all corners in the drawing. Does anyone have any comments or ideas on how to go about this task?
    Thanks in advance.
    Charlie
    Certified BIM Addict Brian Myers's Avatar
    2003-02
    Working in Cyberspace
    1,682
    Default Re: Archectural floor plan to single line schematic
    Are you using just AutoCAD 2006?
    Are your existing walls just on one layer (by themselves)?
    Just trying to get a feel for your setup....
    Brian Myers
    Sr Applications Engineer, Seiler Instrument | Autodesk Certified Instructor (ACI) Revit Architecture
    Creator of the Revit Users LinkedIn Community | Author of Revit Videos @ Lynda.com
    2002-05
    141
    ACAD 2006
    Walls would be separated into layers based on construction materials.
    2002-05
    141
    I have been tasked with converting architectural drawings into single line schematics with no void space. Can anyone think of a routine that will assist me in this endeavor.
    2001-03
    13,499
    Hi Charlie
    Please note I have merged the above post with your original thread ( ie This thread ).
    Why? - Both relate to the same query, question - therefore it greatly helps the process if everything is kept in one place... people coming to offer assistance / help are able to see the complete picture so far...
    Thanks, Mike
    Forum Moderator
    2005-04
    20
    I'm not sure if this will help, but it might: I have this lisp file that asks you to select two lines, then places a line midway between them, then using a crossing window you can delete the original lines. You would then have to clean up all the intersections, but at least it would be a start. Maybe someone out there can improve upon this.
    Kevin Barrett
    CAD Drafter
  1. Schematic Floor Plan - Single Line
    By antman in forum Revit Architecture - General
    Last Post: 2011-06-06, 07:37 PM
  2. Plan View, Single Line Plumbing
    By kirby-h in forum Revit MEP - General
    Last Post: 2009-06-10, 05:03 PM
  3. Plumbing Plan (single line) Using Revit Architecture
    By Firmso in forum Revit Architecture - General
    Last Post: 2008-02-21, 12:56 PM
  4. Single line plan in revit- tip
    By nikhil.nayak in forum Revit Architecture - Tips & Tricks
    Last Post: 2007-09-30, 09:11 PM
  5. Fascia-line visible in floor plan
    By anders.hedman in forum Revit Architecture - General
    Last Post: 2004-06-14, 08:16 PM
