Results 1 to 10 of 17
Thread: how to edit/change text size in mtext
    Member sbradford's Avatar
    2005-10
    Las Vegas
    14
    Default how to edit/change text size in mtext
    I am trying to change my text size for one word not the whole mtext and it will not let me change individuals it only goes through and changes the whole mtext i will post a example and maby it will help everyone understand what i am asking any help would be appreciated
    2005-10
    Las Vegas
    14
    Default Re: how to edit/change text size in mtext
    i am trying to change the text height of note only and it keeps changing all of my text
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by sbradford
    How are you trying to change the text height of the word "NOTE"? What are the steps you are doing?
    2005-10
    Las Vegas
    14
    i am in the text edit formatting and i am selecting the word note and trying to change it by our style (L 80 to B 140) and it changes the whole mtext i know i can go and change the text height for individual words by changing the text height from .8 to 1.4 but we try and follow our cad standards so the next person does not get screwed up.
    2001-05
    Austin, TX USA
    2,201
    You can't use different text style in one mtext. You can change the font type and size. Highlight the text and use one of the other drop downs
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    What software and what version are you using? MTEXT has different capabilities in different versions.
    One cheat that I use is to make the word "NOTE:" a different piece of text.
    2005-10
    Las Vegas
    14
    i am sorry i am using land desktop 2005. that is what i have be doing creating a different piece of text just thought there was a way to possibly do it in a single mtext rather than two separate pieces
    13,656
    Hi
    You could look as using something like NotePad as your Multiline Text Editor, you could then apply the required formatting codes.
    For information of formatting codes ( if required ), refer to the AutoCAD Online Help File [F1] -
    "Format Multiline Text in an Alternate Text Editor"
    Have a good one, Mike
    2005-10
    Las Vegas
    14
    thanks mike i will give that a try today when i get some free time
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    Quote Originally Posted by Mike.Perry
    Be aware that if you add formatting that isn't supported by the standard MTEXT editor, this can cause headaches for other people who open your drawing and try to edit the MTEXT in the standard MTEXT editor.
    And it isn't really any different than selecting the word in the MTEXT editor and changing the height.
    Has the MTEXT editor been improved in 2006? As it is, I'm amazed that Autodesk kept the same POS editor through so many versions...
  1. 2014: want to edit mtext and other mtext also change
    By radosak368138 in forum AutoCAD General
    Last Post: 2013-04-27, 12:03 PM
  2. 2004: When I change dimn. text size, won't change in model space.
    By lucky13gurl420508758 in forum AutoCAD General
    Last Post: 2012-11-07, 06:19 PM
  3. Changing font size in within MTEXT edit mode.
    By Merlin in forum AutoCAD General
    Last Post: 2009-08-31, 10:19 AM
  4. text edit size problem
    By ..shaner in forum Revit Architecture - General
    Last Post: 2006-05-09, 09:24 PM
  5. Edit mtext size (mtextfixed)
    By mlepelletier in forum AutoCAD General
    Last Post: 2005-10-21, 06:20 PM
