My pregnant brain just doesn't want to understand lisp these days.
I have a new employee using this and i can't figure out what this routine is actually doing.
(defun item (n e)
(cdr (assoc n e))
(defun mend-error (s)
(if (\= s "Function cancelled")
(princ s)
(if ename1
(redraw ename1 4)
(command ".UNDO" "END")
(setvar "CMDECHO" 1)
(princ)
(defun selent (typ ord /)
(setq en nil)
(if (= ord 0)
(setq ord "")
(if (= ord 1)
(setq ord "first ")
(if (= ord 2)
(setq ord "second ")
(while (null en)
(if (setq en (entsel (strcat "\nSelect " ord typ ": ")))
(progn
(setq ename (car en))
(setq edata (entget ename))
(if (/= (cdr (assoc 0 edata)) (strcase typ))
(progn
(prompt "\nEntity is a ")
(princ (cdr (assoc 0 edata)))
(setq en nil)
(redraw ename 3)
(defun mend1 (/ ans ok es1 ename1 int1 int2 ent1 es2 ename2 ent2 plist
qlist)
(setq ans nil)
(if (not selent)
(load "selent")
(selent "LINE" 1)
(setq ent1 edata
ename1 ename
(selent "LINE" 2)
(setq ent2 edata
ename2 ename
(setq int1 (inters (cdr (assoc 10 ent1))
(cdr (assoc 10 ent2))
(cdr (assoc 11 ent2))
nil
(setq int2 (inters (cdr (assoc 11 ent1))
nil
(if (or int1 int2)
(progn
(initget "Yes No")
(setq
ans (getkword
"\nSegments are not on same line - join anyway? <N>: "
(if (= ans nil)
(setq ans "No")
(if (/= ans "No")
(progn
(setq plist (mapcar '(lambda (p1 p2)
(list (distance (item p1 ent1)
(item p2 ent2)
p1
p2
'(10 10 11 11)
'(10 11 10 11)
qlist (item (apply 'max (mapcar 'car plist)) plist)
ent1 (subst (cons (- 21 (car qlist)) (item (cadr qlist) ent2))
(assoc (- 21 (car qlist)) ent1)
ent1
(entdel ename2)
(entmod ent1)
(progn
(if ename1
(redraw ename1 4)
(if ename2
(redraw ename2 4)
(defun c:mend (/ olderror *error* ce)
(prompt "\nCommand: MEND ")
(setq ce (getvar "CMDECHO")
olderror *error*
*error* mend-error
(setvar "CMDECHO" 0)
(command ".UNDO" "begin")
(mend1)
(command "UNDO" "END")
(print)
(print)
[ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
