below is some code that selects objects that are on a specific layer. What code do I need to add for selecting only model space objects? I tried to use a set command to reference model space but this did not work. Any help is appreciated. I also want to take the model space selection set and create a block from the objects. Would i need to check the block table for the block if it exists in the drawing?
Sub scalebar()
Dim sstext As AcadSelectionSet
Dim entObj As AcadEntity
Dim FilterType(0) As Integer
Dim FilterData(0) As Variant
Dim mode As Integer
mode = acSelectionSetAll
Set sstext = ThisDrawing.SelectionSets.Add("SS2")
FilterType(0) = 8
FilterData(0) = "G-TTLB-PLBK"
sstext.Select mode, , , FilterType, FilterData
sstext.Delete
End Sub
