Thread: Plot PLT files via Sheet Set Manager
    2005-09
    7
    Default Plot PLT files via Sheet Set Manager
    I would like to plot about 30 drawings from 3 different projects at the same time. They are all part of the same sheet set. I have no problem plotting to file separately, but when I highlight them all and plot, all the drawings go to just one plot file. Is there any way that I can tell the ssm to break the sheets into separate plt. files with separate names?
    13,656
    Default Re: Plot PLT files via Sheet Set Manager
    Hi
    Have a browse of the following threads...
    Batch Plotting PLT files with Sheet Set Manager
    Publish .plt files
    Plot to file in sheet sets?
    Have a good one, Mike
  1. 2016: plot to PDF form sheet set manager
    By tim_newsome in forum AutoCAD Civil 3D - General
    Last Post: 2015-08-04, 07:36 PM
  2. Replies: 4
    Last Post: 2013-11-18, 02:24 PM
  3. Plot 2 layouts from 2 different files on same sheet
    By Yancka in forum AutoCAD Plotting
    Last Post: 2007-11-27, 12:09 PM
  4. Plot a Custom Title Block from Sheet Set Manager
    By luke.siebert in forum AutoCAD Plotting
    Last Post: 2005-02-23, 01:56 PM
