Thread: AUGI Guage with ADT2004 ?
    2005-11
    6
    Default AUGI Guage with ADT2004 ?
    Hi all,
    I'm trying to design new workstations for my CAD users, and we use Architectutaral desktop 2004.
    I tried to use the AUGI gauge program with ADT4, but I am having problems. When I run the script, it will load a file, but does not apear to do anythig. If I manually close the file, it will open another one, but it does not seem to run any operations.
    The command line shows the error:
    *Setting system variables
    error: AutoCAD variable setting rejected" "DRAWORDERCTL" 0
    Does this bencmark program work with ADT4? Is there something I can change to make it operate?
    Thanks
    Jim
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    Default Re: AUGI Guage with ADT2004 ?
    I have heard of other members using it sucessfully on ADT 2004, however the AUGI Gauge is no longer supported, so I wouldn't know where to go with this. I've found that with most new computers these days, running programs has become less of an issue.
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
    2005-11
    6
    OK, thanks Steve.
    So, what tools are people using nowadays to test AutoCAD performance?
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,285
    Talking Re: AUGI Guage with ADT2004 ?
    Quote Originally Posted by jhelfer
    OK, thanks Steve.
    I, personally, have not used benchmarking software (they just buy me what my secretary uses anyway), and I hadn't really seen the topic come up much here, but, I saw quite a few threads on the Autodesk discussion groups hardware forum. Good luck.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
  1. Augi Guage 2010
    By c.prettyman in forum CAD Management - General
    Last Post: 2010-01-27, 04:35 PM
  2. guage thickness to inches/mm
    By CADBIMManager in forum Inventor - General
    Last Post: 2005-12-01, 06:58 PM
  3. Would ADT2004 be enough for my dwg. purpose?
    By maryam in forum ACA General
    Last Post: 2005-05-11, 04:24 PM
  4. ADT2004 to ADT2
    By mary.west in forum ACA General
    Last Post: 2005-02-23, 04:50 PM
  5. adt2004 and accurender
    By blardizabal in forum ACA General
    Last Post: 2004-09-02, 01:59 PM
