Results 1 to 10 of 13
Thread: Making a pdf file- creating problem
    Member sudhirkizhakoote's Avatar
    2005-10
    24
    Exclamation Making a pdf file- creating problem
    while i am creating some drawing files (which include so many images) into pdf file, it is taking a lot of time and atlast the system will get hang.how it happened. did anybody is having any answer ? is it the problem of system(ram is 1GB) or Acad. i am using ACAD 2005.There is any other software to make pdf files other than Adobe pdf professional.i am attaching the files.please let me know
    Last edited by sudhirkizhakoote; 2005-11-29 at 07:31 AM. Reason: Adding the attachments
    ACA/AMEP Forum Moderator arcadia_x27's Avatar
    2003-10
    The 'Mill,Moncton, NB, Canada
    516
    Default Re: Making a pdf file- creating problem
    Can you post a sample drawing so that thos of us here can take a look at it and try to replicate the problem. I suspect though its the fact that your drawing has images in it. What are the specs of the system youre creating the PDF's on?
    Jason Goodwin
    Using ACA 2012
    Super Moderator blads's Avatar
    2003-05
    South Australia
    2,242
    Quote Originally Posted by sudhirkizhakoote
    while i am creating some drawing files (which include so many images) into pdf file, it is taking a lot of time and atlast the system will get hang.how it happened. did anybody is having any answer ? is it the problem of system or Acad. i am using ACAD 2005.There is any other software to make pdf files other than Adobe pdf professional.please let me know
    you could try pdf995 I used to use that before switching to Adobe
    Cheers @blads
     Mac Geek | Building Design Suite Premium 2014 | Multi-award winning Building Designer | HERS Assessor | AEC Applications engineer
    0,0,0 The Origin
    8,027
    It well be that you just need more memory (ram).
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    100 Club charlie.bauer341340's Avatar
    2002-05
    Here, because I'm not all there
    141
    Do you have any gradient fill in the drawing. Adobe does not know how to handle gradient fills and will crash AutoCAD. I also has problems with properly displaying raster images used for wipeouts and masking. I use ArcoPlot, it handles the raster images properly, I haven't tried it on a gradient fill though.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Quote Originally Posted by cadd.32411
    Charlie,
    I have successfully plotted a gradient fill into Adobe's PDF printer driver for Version 6. It made the file pretty big but it did handle the fills. The image had multiple gradient fills, as well.
    I'm not knocking AcroPlot, since I haven't used it. I have always heard good things about AcroPlot anyway.
    2002-05
    141
    Richard
    I just tried to plot a drawing with a large area of gradient fill using Acrobat 6.0 and got an error message saying I was out of memory and it crashed the drawing. I have 1.5 gig of memory. I have used Acrobat 6.0 to plot the same drawing numerous time without the gradient fill and had no problems with it. I have experience this same problem in Acad 2004 2005 and now with 2006. When I plotted the same drawing using AcroPlot it had no problem plotting it and the file size was average for a drawing of that size.
    Perhaps the amount of memory is important when using Acrobat.
    2002-01
    jUSt Here (a lot)
    6,836
    Richard
    It probably is. It sounds like your fills were too much for it. I try not to do too many gradients anyway. I was having to do a rendering for our architectural side, since everyone over there was out of the office.
    If I ever can get the office moved to a common PDF writer I'll probably suggest AcroPlot, due to all the positive comments I've seen.
    0,0,0 The Origin
    8,027
    Didn't Adobe "invent" gradient fills? In Postscript.
    Wouldn't it be nice if they and aDesk got together on this.
    John B
    2005-10
    27
    I kept thinking the file was hanging up but when I checked it was slowly cranking away at it. after 15 minutes or so the file is halfway done but again still ghuging away. I have emails stacking up so I had to cancel it. I think patience is the key on this one. There are so many images attached it's alot to convert.I'll give it another try at home where I can just leave the file to do its thing.
    ::Edit::
    Just checked the pdf that it had created up till I canceled the process and it is over 13 meg. You might look into resizing the jpegs to make a smaller file size or something along those lines. I'm not sure how scaling them up after you insert them into AutoCAD affects the size though.
  1. Problem with making solid
    By ukdodger in forum AutoCAD 3D (2006 or below)
    Last Post: 2008-09-30, 01:23 PM
  2. Replies: 17
    Last Post: 2008-05-02, 04:56 PM
  3. Error Making a .Fas file
    By jmcshane in forum AutoLISP
    Last Post: 2006-07-04, 06:06 PM
  4. Problem creating folder with batch file
    By Borg in forum CAD Management - General
    Last Post: 2005-01-06, 06:58 PM
  5. Making new textures...problem
    By Kroke in forum Revit Architecture - General
    Last Post: 2003-05-15, 02:04 AM
