Thread: ExpressTools - “multiple object stretch" command (mstretch) issue / problem
    Member JMonrex Gadgude's Avatar
    2004-12
    Italy & Philippines
    43
    Question ExpressTools - “multiple object stretch" command (mstretch) issue / problem
    Hello to everybody there!
    Presently I used AutoCAD 2006, I have a problem in express tool which is a “multiple object stretch" command (mstretch). When I stretch a certain objects e.g. line or rectangle (where this lies in a multiple objects) using crossing window in first point of line, and second crossing window in the other point of line, specify option ENTER to continue,,, at the end of this command this line don’t have an equal value on that specific endpoint (Its look a diagonal line).Is this normal in AutoCAD2006, because lately I used AutoCAD2005 and 2000 but no problem occurred compared to AutoCAD2006.
    Is someone telling me how to overcome this problem? Thanks a lot in advance.
    Ciao from Italy!
    2001-08
    58
    Default Re: ExpressTools - “multiple object stretch" command (mstretch) issue / problem
    Try the standard Stretch command in 2006. It now supports multiple crossing windows.
    Chuck
    2004-12
    Italy & Philippines
    43
    Quote Originally Posted by chuck_cantieny
    Chuck
    Thanks !
    It was an additional info/ tricks in AutoCAD2006.
    But It was not work on an equal value at end point of a line (e.g. object).....again this line don’t have an equal value on that specific endpoint (Its look a diagonal line).
    Is someone experiencing this?
  1. Multiple Object Selection Issue
    By zack.meyers in forum CAD Management - General
    Last Post: 2010-11-18, 12:36 AM
  2. Mtext Background vs. ExpressTools Textmask Problem
    By john.miller in forum AutoCAD General
    Last Post: 2008-10-01, 04:05 PM
  3. "Stretch multiple" drafting entities (Revit 101 question)
    By scowsert in forum Revit Architecture - General
    Last Post: 2007-06-06, 08:28 PM
  4. ExpressTools breakline command
    By Grumpy in forum AutoCAD Customization
    Last Post: 2006-06-01, 09:31 PM
