Results 1 to 7 of 7
Thread: About trucks turning radius ..
    Member fred_bock's Avatar
    2004-12
    Quimper (Ouest/France)
    28
    Question About trucks turning radius ..
    Hello to everyone...
    During the day, i was confronted with the question " Do u really think that will work ??"
    .......and I'm not able to say yes !!
    I was doing one of those areas for one truck turn around, get right back wards in front huge door...get loaded with stuff and get along.
    I wonder if you people can lead me into information about the correct way to make those maneuver's areas, and for different type of trucks (European also). something with i can base my design and say Yes !!
    thx
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: About trucks turning radius ..
    Quote Originally Posted by fred_bock
    thx
    You might want to try out PathPlanner. We use it on our site designs. Its a bit tough to create the truck paths in reverse but it works pretty well forwards.
    2002-09
    Madison, WI
    5,687
    Well for software you can look at autoturn.
    Other wise Graphic Standards has some nice info. One thing I can tell you is that the driver makes alot of the difference.
    2005-03
    Derby, UK
    194
    I have no knowledge at all of this sort of thing, but thought the attached document may be usefull.
    2004-12
    28
    Excellent !! thx for those tips !!
    about this "Design for the vehicle" i never hear about, I'll read it carefully, i saw once a quite nice CD of "Graphic Standards" ,(i exported the curve they had) and since then, i use it, but the point is that i don't have the base knowledge to say it works !!
    Here were i work, (France) i use a book that is a bit like this "Graphic Standards" stuff is called "Ernst Neufert – Les éléments des projets de construction" very very good stuff !!
    that i know, it exist in English, German, French, Portuguese (and more i guess ...)
    autoturn i use it once the demo, but the car they give in the demo didn't convinced me !!
    I'll try the demo of this "PathPlanner" seams nice.
    Otherwise i just found in the forum of www.eng-tips.com some nice information about the subject, but still nothing like i law or something, that says the criteria to build one area...
    but thx for the help, keep them coming !! the more the best !
    2006-12
    Maine
    57
    I was on a similar search for Truck turning radiuses. The best I found so far was a Highway Design Manual from California. The last several pages have STAA Templates for truck turn radiuses. I was able to import these into the software I was using (Revit 9.1) as an image and then sketch on top of them.
    The STAA Templates only cover 60', 50' Semi trucks and 40' busses. I used the 40' buss to approximate a 35' garbage truck.
    The attached file is only an excerpt from the original document (which was too large to upload).
    2011-05
    926
    What about "radii"?
  1. Turning Radius Software
    By Iceberg in forum Software
    Last Post: 2019-08-21, 10:44 PM
  2. W-BM Radius
    By tiffany.amorgan in forum Dynamic Blocks - Technical
    Last Post: 2008-01-15, 07:34 PM
  3. Replies: 4
    Last Post: 2008-01-13, 07:56 PM
  4. Turning radius of a forklift
    By Maverick91 in forum CAD Management - General
    Last Post: 2006-02-14, 07:23 PM
  5. Turning radius of a golf cart?
    By stuntmonkee in forum Revit Architecture - General
    Last Post: 2005-08-18, 10:39 PM
