Thread: Layer Management (what's on, what's off)
    I could stop if I wanted to SRBalliet's Avatar
    2004-06
    Near Christiansburg, VA Looking for a closer job!
    495
    Default Layer Management (what's on, what's off)
    We have a perpetual problem in our civil office. It is in inevitable that after all the last minute changes and 25 sets of 65 sheets have been plotted before a job goes out the door, somebody will see a sheet that either has a layer turned on (thawed) or off (frozen) that shouldn't be. Being the draftsman it is told that it is our job to monitor that. Visually doing it just doesn't cut the mustard, a drafter gets desensitized to the drawing after working on it for hours and days.
    We are currently using the Layer Management Tools in Express Tools to set up layer states. But I was wondering what others are doing to prevent this problem. I was almost thinking (that's what I do best, almost think) that a lisp or VBA routine might work that would warn someone who is plotting that the current layer status does not match the Layer State for that drawing. Do you want to proceed or cancel? Anybody have anything like that?
    Any comments or ideas?
    Steve Balliet
    Craig Co., VA
    Civil 3D, Mechanical 2012
    2004-06
    495
    Default Re: Layer Management (what's on, what's off)
    Forum Moderator, can we move this to a more appropriate Forum? Take your pick. I not getting any feedback from this one.
    Thanks
    Steve Balliet
    Craig Co., VA
    0,0,0 The Origin
    8,055
    If the desired state is constant or one of a small group of states, how about running a script that sets each layer to the standard?
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2001-03
    13,499
    Hi
    Try plugging the following search criteria into the forum search facility...
    Key Word(s): Layer + *State* + Layout
    Have a good one, Mike
    All AUGI, all the time Alex Page's Avatar
    2003-07
    Wellington, New Zealand
    796
    it isnt the most failsafe way, but its pretty good...
    We have reprogrammed everyone not to thaw or freeze layers in the 'sheets' once they have been setup with the right layers frozen/ thawed.
    When staff need to for visual 'temp' purposes, they use on/off instead and we just use a startup script which turns 'on' all layers. We also have a button for 'turn on all', so staff got used to it pretty quick (ie: easier for them to turn off layers and then 'turn on all' instead of working out which layers they need to thaw)
    Hope this helps
    Alex Page
    RevitWorks Ltd
    Check out the Door Factory, a door maker add-in for Revit
  1. layer management
    By dstarr in forum Training
    Last Post: 2010-01-25, 10:31 PM
  2. Layer Management
    By Spanky in forum AutoCAD General
    Last Post: 2007-08-17, 02:08 PM
  3. Layer Management
    By jbayne in forum ACA General
    Last Post: 2005-05-09, 09:47 PM
  4. Layer management and Viewpots
    By mark_a in forum AutoCAD General
    Last Post: 2005-03-15, 12:44 PM
