Results 1 to 6 of 6
Thread: Isometric Dimension
    I could stop if I wanted to Merlin's Avatar
    2004-05
    Brisbane, Australia
    405
    Question Isometric Dimension
    Hi,
    I've not worked with the Isometric snap since I did an AutoCAD course when I started in this profession. I currently doing up a detail in isometric (ie a 2D drawing done with the Isometric snap on ...not 3D drawing displayed from an Isometric View) and all is fine with the drawing itself.
    However I'm about to give it annotations etc. and suddenly realised an Isometric looking dimension for it is something I'm unfamiliar with. Any of my attempts to insert a dimension displays a dimension on the usual front plane....Of course, I could just fake it and draw it up manually or explode one and alter it but I was wondering if there is a short way (or command) I could do?
    Anyone?
    cheers,
    John Mc
    2004-08
    Iron Station, NC
    3,198
    Default Re: Isometric Dimension
    try adding an oblique angle to the dimension (I think that is what you are looking for)
    it is under the menu Dimension->Oblique
    AUGI Director scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    Also assign a text style to the dimension that has the text obliqued. You will need 2 text styles, 1 for each iso direction (obliquing angle 30, and obliquing angle -30).
    2004-05
    Brisbane, Australia
    405
    Question Re: Isometric Dimension
    Quote Originally Posted by ccowgill
    Hi,
    Thanks for the response...I've tried your suggestion and I just get movement of the dimension as a whole (it remains essentially unchanged...just moved) without it's "skewing" to an oblique form...I'm doing something wrong.
    John Mc
    2004-05
    Brisbane, Australia
    405
    Smile Re: Isometric Dimension
    oops!....NOW it's working...( I forgot I had a "user arrow" for my dimension ticks)
    Thanks Gang!
    2004-05
    Brisbane, Australia
    405
    Quote Originally Posted by scott.wilcox
    ....and that was the icing on the cake!!!
    Thanks, mate!
  1. How-to Dimension Isometric drawings
    By mjpestalitz in forum AutoCAD General
    Last Post: 2021-06-17, 08:58 AM
  2. Isometric Dimension.....
    By somared in forum AutoCAD General
    Last Post: 2014-01-13, 05:51 AM
  3. 2014: How do I fillet, chamfer, and dimension in isometric?
    By Vagulus in forum AutoCAD General
    Last Post: 2013-08-30, 04:45 PM
  4. Isometric
    By wdvaden in forum AMEP General
    Last Post: 2009-10-16, 04:17 PM
  5. Replies: 3
    Last Post: 2007-11-16, 11:56 PM
