Results 1 to 1 of 1
Thread: Dims and Temp Dims not working sometimes
    The CADSmith Chad Smith's Avatar
    2003-05
    Brisbane, Australia
    1,729
    Default Dims and Temp Dims not working sometimes
    Is anyone else having problems with dims and temp dims not moving objects when changing their values?
    Take the attached example file. Try moving the dashed line that is dimensioned by using the dimension. Now try moving the other dashed line using a temp dim that is referenced to the inside of the wall.
    And finally, try adding a new detail line, and either using a dim or temp dim to move it in relation to the wall, NOT the grid.
    There seems to be some kind of bug in which dimensions aren't working properly when referenced to a wall that is LOCKED to a grid.
    This is happening on my other projects as well.
  1. Temp Dims on Revit's 2d toilet
    By 3dway in forum Revit Architecture - General
    Last Post: 2010-07-13, 08:07 PM
  2. Dims not working same - depends on size
    By irneb in forum AutoCAD General
    Last Post: 2009-07-20, 07:03 AM
  3. Temp Dims
    By sjsl in forum Revit Architecture - General
    Last Post: 2005-02-03, 02:36 PM
