Thread: Framing Plan not Scheduling Level
    2003-10
    Michigan
    468
    Default Framing Plan not Scheduling Level
    I am working on a framing plan in 8.1. I have made a schedule with the Level parameter, but it comes in blank. Each joist shows up and when I check the Element Properties, it shows the correct level & work plane in gray.
    Is there something I am missing?
    100 Club A3D's Avatar
    2005-01
    Barcelona, Spain
    126
    Default Re: Framing Plan not Scheduling Level
    Try scheduling using Reference Level instead of Level.
    I do it this way because level always stays in blanc.
    2003-10
    Michigan
    468
    Thanks!!! That worked, I didn't see that in the list.
    Doug
  1. Scheduling the level a mass is placed on
    By davidwlight in forum Revit Architecture - General
    Last Post: 2024-02-04, 10:54 PM
  2. 2015: 1st level objects greyed out and visible on 2nd level floor plan
    By booyahhhnia342307 in forum Revit Architecture - General
    Last Post: 2015-06-11, 03:14 PM
  3. 2014: scheduling columns and framing together?
    By evan549822 in forum Revit Structure - General
    Last Post: 2014-07-21, 09:06 AM
  4. 2011: Multiple Arch. backgrounds on the same level framing plan
    By clhattel in forum Revit Structure - General
    Last Post: 2011-09-16, 11:32 PM
  5. Roof framing showing on an upper floor framing plan
    By REVIT_MONKEY in forum Revit Structure - General
    Last Post: 2009-08-04, 04:14 PM
