Thread: How to grey-out Rough Width and Rough Height parameters
    AUGI Addict Scott Hopkins's Avatar
    2003-05
    Santa Barbara, CA
    1,197
    Default How to grey-out Rough Width and Rough Height parameters
    In window and door families, to a make Rough Height and Rough Width dimensions greyed-out and non -editable try by the end user, try the following trick...
    1) Make a new parameter called "Make it Grey". Give it a value of zero in the formula column.
    2) In the formulas column add "Make it Grey" to the formulas for Rough Width and Rough Height
    This will work for any parameter that has its dimension based on another parameter (Rough Width and Width for example). Also remember for parameters that don't need to change, if you put their value in the formula column they will show as grey to the end users of the family ("Make it Grey" in the above example).
    Unfortunately what is missing is a way to make non-dependent parameters (i.e. Width and Height) non-editable by the end user. See this wishlist post for more info on this...
    http://forums.augi.com/showthread.php?t=29941
    2013-01
    6
    Default Re: How to grey-out Rough Width and Rough Height parameters
    Nice tip Scott. Thanks
  1. ROUGH GRADE SLOPES
    By mgonzales361438 in forum AutoLISP
    Last Post: 2013-07-30, 10:01 PM
  2. door rough opening
    By cr_gixxer in forum Revit Architecture - General
    Last Post: 2011-10-18, 04:27 PM
  3. Dimension to rough openings
    By Denis01 in forum Revit Architecture - General
    Last Post: 2010-08-18, 01:53 AM
  4. Rough Opening Coordination
    By T.W.Allen in forum Revit Structure - General
    Last Post: 2010-04-27, 09:58 PM
  5. dimension to Rough Width
    By tom mars in forum Revit Architecture - General
    Last Post: 2006-04-06, 11:46 AM
