Thread: Command line view missing!
    2005-12
    2
    Default Command line view missing!
    There I was blazing away at a drawing due in moments and to my surprise my command lines stopped being written as I typed in commands. Somehow somewhere, I must have changed the settings but I could find no thread of evidence to that effect. Does anybody know why I can't see my command lines anymore? the space and the cursor is still there bu there are no words, no numbers, nothing. Black on black. The letters are supposed to be white but they are not there.
    AUGI Addict Augi Doggie's Avatar
    2002-01
    Orlando, FL.
    1,348
    Default Re: Command line view missing!
    This might not be the best forum for this question so don't be offended if a Moderator moves it.
    Try this to fix your problem. Type "Options"; go to the "Display" tab; in the "Windows elements" section select "Colors"; there is a scroll bar called "Window Element" scroll down to "Command Line Text"
    That is the setting you're looking for. Change the color there. I hope that helps!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Please note I have *moved* this thread from the New Forum Users Forum to this one as I believe it would be better served here.
    Below snippet is from the small print on the Forum General page -
    <snip>
    New to the Forums? This is the place to experiment with the posting editor and learn how to interact with our forums. Please experiment here with forum features and commands.
    </snip>
    Richard
    Forum Moderator
    Active Member chadwickt's Avatar
    2015-12
    84
    Are you in ACAD 2006? Is there any chance that you turned on dynamic entry? (The DYN button on the status bar).
    If dynamic entry is on you would not see the commands being typed in (they would be next to your crosshairs) but you should still see all the options of the current command...
    I could stop if I wanted to H.Hunter's Avatar
    2005-08
    Somewhere, but not here
    241
    Are you talking about the dynamic input line (2006) or the actual command line toolbar?
    I do remember in one previous version, if you scrolled up the command line it wouldn't return to the bottom even if you kept working. You'd have to go back to the bottom manually. (At least I think it was AutoCAD.)
  1. 2013: Insert block dialog missing - shows at command line instead
    By alpevarnek in forum AutoCAD General
    Last Post: 2012-12-18, 06:59 PM
  2. Command Line Box - Missing
    By bob.kalsi66006 in forum AutoCAD General
    Last Post: 2009-07-09, 09:33 AM
  3. AutoCAD R14 - Missing command line...
    By blads in forum AutoCAD General
    Last Post: 2007-01-16, 01:02 PM
  4. view top within line command
    By louis.64641 in forum AutoCAD 3D (2006 or below)
    Last Post: 2005-07-21, 02:57 PM
  5. Missing text in command line
    By john.73967 in forum AutoCAD LT - General
    Last Post: 2004-08-29, 02:11 PM
