Results 1 to 9 of 9
Thread: Linetype text direction on arcs
    I could stop if I wanted to Ammon's Avatar
    2005-06
    Salt Lake City, Utah
    423
    Default Linetype text direction on arcs
    I have had this problem before but I can't find a thread on this issue.
    Does anyone know if there is a way to change the direction of text in custom lintypes on arcs. No matter which direction I draw the arc it always has the top of the text towards the center.
    Thanks in advance.
    0,0,0 The Origin
    8,569
    Default Re: Linetype text direction on arcs
    Would you believe it? I saw a tool to do just this last night on a web site that I can't recall.
    It is out there. I'll keep looking.
    John B
    13,626
    Hi
    Take a look at the routines offered in this post ( RE: change linetype direction ).
    Have a good one, Mike
    0,0,0 The Origin
    8,569
    Okay. Not a straight-forward tool but -
    "Q. How to change the direction of text in complex linetype in arcs?
    A. Texts in complex linetypes (e.g. in the standard AutoCAD "GAS" linetype) is drawn in the direction the line was drawn. But arcs are drawn by AutoCAD always in the same direction, so texts always face inside arcs with their top side.
    If you convert an arc to a polyline (_PEDIT), you can reverse its direction and then the text changes its orientation (if you have the object property 'linetype generation' set to On)."
    Next, you need a routine to reverse the direction of the pline. I've tried 2 routines this evening but neither worked correctly in A2006 .
    Sorry, I don't have any more time this evening but Google search "reverse polyline" and you should find something.
    Luck.
    John B
    2005-06
    423
    Quote Originally Posted by johnbogie
    Luck.
    I appreciate the help brother John. I'll do that search. Thanks.
    2005-06
    423
    Quote Originally Posted by Mike.Perry
    Hi
    Thanks Mike. I hope these routines work for the arcs.
    13,626
    Quote Originally Posted by ammon
    Hi
    Hint - rpoly.lsp does
    Did for me when I carried out tests earlier today...
    0,0,0 The Origin
    8,569
    Hi
    Nice one Brother Mike.
    I realised why the routine I tried (rev.lsp) didn't work and it was my fault.
    One other possible workaround would be to draw a new polyline over an existing arc using Pline/Arc/Second point options and picking End/Mid/End points on the arc in a clockwise direction.
    John B
    2005-06
    423
    Hi
    Thanks you guys. You're both scholars and gentlemen. Have the drink of your choice on me. (Not on company time of course)
  1. Replies: 8
    Last Post: 2010-10-20, 07:16 PM
  2. Replies: 4
    Last Post: 2007-11-26, 10:22 PM
  3. Preset Text Direction
    By Henry D in forum Revit Architecture - Wish List
    Last Post: 2007-08-08, 08:08 PM
  4. change linetype direction
    By andrewp in forum AutoCAD General
    Last Post: 2005-05-24, 08:07 PM
  5. Snaps: Text, Circles & Arcs
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2003-09-03, 01:49 AM
