Steve_Bennett
I forget - which version of ADT are you on? 2005 or 06?
Your sash is not showing up because the bottom of the wall is floating in air. Stick it down at a zero elevation & it will show - similar to the stock ADT wall I added to the dwg. Either that or bumping up the sill height from zero to about 6" above 0" grade will cause the sash to show.
On a side note, I noticed that in the file you posted, the DWA was not anchored to the wall that it appeared to be sitting in. You can add the window back into the drawing & re-select which wall it is attached to. Or you can pick the existing window, right click & choose "Anchor to Wall". I don't really trust this method as it produces what I call "unpredictable results".
