Thread: Creating 3D rendering in AutoCAD
    2005-01
    84
    Arrow Creating 3D rendering in AutoCAD
    We can’t afford to have sophisticated 3D software like Architectural Desktop, Autodesk viz, etc. but instead I want to learn on how to create 3D in Auto-CAD.
    How efficient is the 3D tools command in Auto-CAD? Can anyone give me clue on how to set-up and draw a simple perspective view objects w/ rendering? Is Auto-CAD 3D tools has a capability of creating a perspective rendering view out of 2D floor plan of any simple residential house?
    Ted (Detsenira)
    Auto-CAD 2005 user
    All AUGI, all the time Alex Page's Avatar
    2003-07
    Wellington, New Zealand
    796
    Default Re: Creating 3D rendering in AutoCAD
    Yep...not a problem, but inefficeint in time, mainly because my experiance shows that the 3d autocad model is one-off.....ie: if changes need to be made to a bit of it its easier to delete it and redraw it....
    have a look at tutorials, solid modelling is the way to go.......
    make layers correspond to matarial so you can assign
    materials to layers later.
    Have a look at dview commands for viewing etc etc
    Alex Page
    RevitWorks Ltd
    Check out the Door Factory, a door maker add-in for Revit
    2001-03
    13,499
    Hi Ted
    Please note I have *moved* this thread from the AutoCAD General forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    2001-03
    13,499
    Hi
    The following posts contain a few links to tutorials that might prove useful...
    RE: Looking for Rendering Advice
    RE: Learning 3D drawings in AutoCAD 2005
    Have a good one, Mike
    2005-01
    84
    Thanks Mike and Alex for sharing your Ideas and links of interesting site related to the subject topic.
    I am presently working my first 3-D project and I fell comfortable in creating the image the way I want it to be, except I can't successfully apply or use some of the editing command like extend, cut, trim and others. Instead I used to draw an over sized object inserted to the object I want to cut and used subtract to erase an extra object and Its a little bit time consuming.
    Again thank you,
    Ted
  1. Creating Schedules in AutoCad
    By daniel.191403 in forum AutoCAD Customization
    Last Post: 2011-01-13, 07:04 PM
  2. Replies: 2
    Last Post: 2006-05-18, 08:49 PM
  3. Rendering in AutoCad
    By tom_ola in forum ATP Course Wishlist
    Last Post: 2005-11-16, 06:44 AM
  4. Creating a topography from autocad
    By Max Lloyd in forum Revit Architecture - General
    Last Post: 2005-09-28, 06:48 PM
  5. Replies: 5
    Last Post: 2004-07-22, 12:03 PM
