Thread: alphabet toolbar
    2002-11
    2
    Default alphabet toolbar
    Do you know of an Autocad toolbar that the buttons emulate the standard keyboard. Or a way to make a keyboard toolbar. I find when I am doing a lot of revisions to cad drawings, I have only one hand available for input as my other is crossing of the changes as I make them. A lot of times I just need to revise one letter of something and it is real time consuming to keep switching from the keyboard to the mouse
    Thanks for your help
    Phil
    Houston
    7,519
    Default Re: alphabet toolbar
    Try Windows Start menu | Run | OSK
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    Kewl, thanks for the tip.
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,706
    If you want to start the Windows keyboard with a AutoCAD command you can use this function
    (defun c:keyb ( / ) (startapp "OSK" ) (princ) )
    and then type
    Command: keyb
    : ) Happy Computing !
    kennet
    2002-11
    2
    Thumbs up Re: alphabet toolbar
    Wow,
    That is an awesome tip
    Thanks
    Phil
  1. 2012: Autofill alphabet
    By dknock in forum AutoCAD Tables
    Last Post: 2012-01-05, 06:05 PM
  2. Toolbar Icons Don't Match Toolbar Function
    By walkonfire984109 in forum AutoCAD LT - General
    Last Post: 2010-11-17, 07:04 PM
  3. Is there an easy way to have a Toolbar button call up another Toolbar?
    By jonathanschade in forum AutoCAD CUI Menus
    Last Post: 2007-04-12, 04:40 PM
  4. Toolbar images not being successfully applied to custom toolbar
    By tbrown.113150 in forum AutoCAD CUI Menus
    Last Post: 2007-04-06, 05:06 PM
  5. Fillet Short /Alphabet Command
    By mtjnien.68601 in forum AutoCAD General
    Last Post: 2006-04-20, 02:41 AM
