Results 1 to 10 of 19
Thread: Printing elevations w/ shadows
    2004-06
    Memphis TN area
    7,048
    Default Printing elevations w/ shadows
    If I have a sheet with 2 exterior elevations with shadows turned on, why does it take sooooo long to send the sheet to the plotter? I mean I can understand the shadows bogging down the system when moving around in the view or in 3D or whatever, but why does it seem so slow just to send the sheet to the plotter? It's taking about 10 minutes just to send a single sheet to plot, containing 2 elevations with shadows turned on. Normally it takes about 30 seconds to send the sheet.
    *edit* make that 15 minutes and the Revit progress bar is only up to 66%
    *edit again* 17 minutes total to spool a single sheet
    2004-05
    792
    Default Re: Printing elevations w/ shadows
    That's becuase shadows are displayed and plotted as raster images, much slower as you now know. Everything else in Revit is by vectors. There is no work around except to buy a plotter with a Fiery engine and then theres no or little time lag. We have large color plots that can take up to 30 min to get them out.
    Try exporting the image out as a jpeg and then import back into the sheet. Big difference?
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    Perhaps another reason to print to DWF, then from DWF Viewer to printer.
    2004-06
    Memphis TN area
    7,048
    Quote Originally Posted by sjsl
    what is that? Currently we're running an Oce TDS600 large format laser plotter. Once spooled, sheets print in about 10-20 seconds each (vs. many minutes on our HP DesignJet plotter, which we still use for color).
    2002-02
    St. Louis, MO
    4,695
    Quote Originally Posted by truevis
    No use. Still takes as long to output to DWF.
    2004-05
    307
    Same with A2-A1-A0 PDF, even on a dual core Dell with 2 gigs of ram.
    A3+ prints on a I9500 Canon is 20+ min.
    I could stop if I wanted to kpaxton's Avatar
    2004-12
    Sarasota, FL
    493
    I'll have to chime in on this one too. We've run into the same 'shadow-lag' that you have run into. I've found that using the 'export to jpg-then reimport and link on a sheet' method will work fine, as long as you get a large enough resolution. However I get concerned about making sure the scales correct and that someone doesn't accidentally move or scale it inappropriately. I perfer printing to PDF's or DWF's when it comes to shadowed elevations. You still will need to wait for it to process, but the result can be very nice indeed. Plus you end up with a file you can send anywhere (Client, Repro house, etc.) and have it printed anytime. IF you're just doing check plots, and the shadows aren't that important, then just turn them off. Save those for when you've got some time.
    Hopefully the raster management algorithms will be getting better in the next release.
    Kyle
    I could stop if I wanted to funkman's Avatar
    2003-10
    Sydney, Australia
    437
    Recently I printed off around 10 copies of elevations with 4xfull shadowed views. Although there was a lag, it wasnt too bad, and nothing more than 5 minutes in total.
    While I feel your pain, was it unbearable? Certainly not for me. I spent that time collating and writing letters. Why wait for printers to print?
    AUGI Addict blads's Avatar
    2015-10
    out cycling somewhere... I wish...
    2,285
    I'm inclined to agree with Funkman on this, whilst in v8.0 it was a problem, v8.1 seems faster...
    Cheers @blads
    Mac Geek | Building Design Suite 2020 | Semi-Retired Building Designer / CAD-BIM Trainer | Autodesk Certified Professional
    2004-06
    Memphis TN area
    7,048
    perhaps some of my lag time stems from the fact that our template has been copied and copied and copied as new versions are released. I'm going to try to re-create a new 8.1 template from scratch in the near future.
  1. 2013: Printing elevations with shadows on
    By albino394381 in forum Revit Architecture - General
    Last Post: 2013-10-31, 03:11 AM
  2. 2013: Printing elevations with shadows on
    Last Post: 2013-10-22, 04:36 PM
  3. Controlling how shadows look beyond on elevations?
    By jon.200969 in forum Revit Architecture - General
    Last Post: 2010-08-16, 03:44 PM
  4. Sun Shadows on Elevations
    By aalomes in forum Revit Architecture - General
    Last Post: 2004-10-29, 06:10 PM
  5. shadows on elevations
    By davidwlight in forum Revit Architecture - General
    Last Post: 2004-02-26, 08:53 PM
