Thread: Occupancy Load Form - Spread Sheet calc.
    I could stop if I wanted to rhayes.99001's Avatar
    2005-11
    New Jersey
    349
    Post Occupancy Load Form - Spread Sheet calc.
    I would like to set up a Occupancy Load Form in AutoCAD and
    have the Calc's done automatically.
    What can I use to do that.????
    I could stop if I wanted to Baghera's Avatar
    2002-04
    Halifax NS Canada
    397
    Default Re: Occupancy Load Form - Spread Sheet calc.
    Tables in 2k6 should be able to do what you want, otherwise you'll have to write a LISP routine or use Excel.
    Loyalty above all else except honor
    For my honor is my life!
    Member james.emoore's Avatar
    2005-06
    19
    Are you using straight AutoCAD or one of the Veritical Packages (ADT or Building Systems)?
    [James E. Moore, RA (US-IA)
    SchenkelShultz Architects
    2005-11
    New Jersey
    349
    We are using ADT 05'
    2005-06
    19
    Using spaces in ADT, you could develop a Property Set Definition that holds the occupancy rate from the code and then calculates the occupancy load based on that rate and the area of the space. You could either have the occupancy field be set using the space properties extended data, or as a style based property with a library of preset space styles. You could then create a schedule that displays the space, occupancy rate/and or type, and occupant load.
    If you do take the information into Excel, you still have to find a way to specify the occupancy type. This would include pulling the area and space name into a given Excel form in a given location, going through and specifying the occupancy type, and then having a lookup table built in Excel to give you the occupancy load.
    The property set definition solution allows you to keep it all in one software. The library of space styles could simply be one for each occupancy you use or is defined by the building code.
  1. Occupancy Load
    By azmz3 in forum Revit Architecture - General
    Last Post: 2017-08-03, 07:12 PM
  2. Calculate Occupancy Load
    By pfaudler in forum Revit - API
    Last Post: 2013-02-27, 05:50 PM
  3. Occupancy Load Tabulation
    By john.cantrell in forum Revit Architecture - General
    Last Post: 2010-10-21, 08:31 PM
  4. Occupancy Load Calc
    By pwmsmith in forum Revit Architecture - Families
    Last Post: 2005-12-04, 03:02 AM
  5. Edit data in spread sheet form without import/export of shape file
    By ctozer in forum AutoCAD Map 3D - General
    Last Post: 2005-01-24, 07:33 PM
