Results 1 to 7 of 7
Thread: Changing block names
    2005-05
    111
    Question Changing block names
    I have a drawing that desided that it would take a window block that I had copyed about 40 times and give each block a new name. The orig. was called window3030 and all the blocks changed and added window3030-flat-1 and so on.
    Is there any way to select all of the blocks and change them back to the orig. window3030 block????
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,237
    Default Re: Changing block names
    Quote Originally Posted by pangell
    You could try the blockreplace command located in the Express Tools. It looks like you use the flatten command on your blocks.
    2005-05
    111
    Yes I can do that but, only one at a time which will take for ever. I would like all at one time.
    I could stop if I wanted to dfarris75's Avatar
    2004-12
    where ever i'm at
    252
    I have been told that it is poor practice to copy a block within a dwg. It is best to insert a new instance of the block each time. Not sure if this may have anything to do with your issue, but you may try it to see if you get the same result.
    Hope it helps.
    2002-01
    jUSt Here (a lot)
    8,237
    Here is a bit of code to change the blocks that have been changed from the Express Tools Flatten command. This will replace the "flatten"ed blocks to the original block definition (without the *-flat-* block name) before the flatten command was executed on the blocks., as long as the original block definition is still within the drawing.
    (defun C:FIXAFLAT ()
      (setq	SSET (ssget "x" (list (cons 2 "*-flat-*")))
    	CNT  0
      (if SSET
        (progn
          (repeat (sslength SSET)
    	(setq ENTITY	(entget (ssname SSET CNT))
    	      BNAME	(cdr (assoc 2 ENTITY))
    	      BNAMECNT	(vl-string-search "-flat-" BNAME 0)
    	      BNAMEBASE	(substr BNAME 1 BNAMECNT)
    	      CNT	(1+ CNT)
    	(if (tblsearch "BLOCK" BNAMEBASE)
    	  (progn
    	    (setq ENTITY (subst (cons 2 BNAMEBASE) (assoc 2 ENTITY) ENTITY))
    	    (entmod ENTITY)
    	    (command "_purge" "Blocks" bname "No")
    	    (while (= 1 (getvar "cmdactive"))
    	      (command "")
      (princ)
    Let me know if you have any problems with this. It does not contain any error handling. It has been tested, but only a little.
    HTH
    2005-05
    111
    I code worked great. The only thing if it could be set to leave the block placement prop. to what is on the drawing and not the block
    EX.. If I have a block and I had to mirror it in my drawing. When I run the code it will bring it back to the orig.
    Can we change the code so it will not change the block placement???
    Thank you
    2002-01
    jUSt Here (a lot)
    8,237
    Thank you
    This really doesn't do anything but replace the "flattened" block to the original block definition. I assumed those blocks are the originally defined blocks that the Express Tools Flatten command have modified. If so, the insertion should not have changed.
    You would need to post a copy of the drawing for me to see what is going on.
  1. Changing the parameters names
    By MartinL in forum Revit Structure - Families
    Last Post: 2010-07-05, 08:24 AM
  2. Changing Block Names
    By amandas in forum Dynamic Blocks - Technical
    Last Post: 2008-08-29, 06:25 PM
  3. Blocks Changing Names
    By amandas in forum AutoCAD General
    Last Post: 2008-08-29, 06:01 PM
  4. Changing Xref names
    By BCrouse in forum AutoCAD General
    Last Post: 2005-08-12, 05:35 PM
