Thread: Publish drawings on a different sheet size.
    2005-11
    8
    Default Publish drawings on a different sheet size.
    I want to use Publish to print my drawings. I've used the page setup to print on 24"x36" paper with my large format plotter. Now I want to plot the same drawings in reduced scale on 11x17" paper on another printer for archive purposes. How do I do that without going back into every drawing file and having to setup another page? I should mention I draw using Model tab only. (This goes back to my early Autocad training when we used the MVSETUP command and set the drawing scale and titleblock size before we started drawing.)
    2005-12
    86
    Default Re: Publish drawings on a different sheet size.
    Hi Scott,
    This might not be the best place to post if you want an answer to your question: I'd try reposting over in the AutoCAD forums (if that's the what you're using?)
    At a guess, I'd try rescaling your prints in your printer driver, or doing something programmatically using lisp or VBA.
    Best of luck.
    13,656
    Hi
    Please note I have *moved* this thread from the AUGIWorld Feedback forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,656
    Hi
    Take a look at the following...
    TIPniques: The Power of Page Setups - October 2005 ( AUGI HotNews article ).
    Oct '05 - TIPniques: Power of Page Setups ( associated thread, found in the Hot News forum ).
    Have a good one, Mike
    2004-08
    Iron Station, NC
    3,198
    open the first drawing, add the page setup there, then save the drawing, run the publish command, open the list of drawings, or create the list of drawings, change the page setup to import, and import if from the current drawing, just use the pull down for all the drawings in the list and save your publish list for later use.
  1. Publish window size
    By CadDog in forum AutoCAD General
    Last Post: 2011-05-31, 01:11 PM
  2. Bogus Sheet size (1000 times defined size)
    By bcgatti in forum AutoCAD Plotting
    Last Post: 2007-12-16, 05:42 PM
  3. Publish does not close drawings
    By smplancic in forum AutoCAD General
    Last Post: 2007-12-13, 04:24 PM
  4. Publish drawings using Page Setups
    By kadar_drafting in forum AutoCAD Plotting
    Last Post: 2007-05-11, 11:44 PM
  5. Plot drawings to PDF sheet size 24x36
    By Globey in forum AutoCAD Plotting
    Last Post: 2006-04-10, 01:04 PM
