Thread: Acceptable abbreviations eg When using cvunit
    2003-07
    14
    Default Acceptable abbreviations eg When using cvunit
    Does anyone know if there is a list of acceptable abbreviations that you can use in AutoCAD? Example: cvunit(43560,square feet,acres) - - AutoCAD will not let me abbreviate square feet to sqft for example. Any suggestions?
    Mert Garrison
    Earth
    9,804
    Default Re: Acceptable abbreviations eg When using cvunit
    Check out the ACAD.UNT file.
    R.K. McSwain | CAD Panacea |
    2003-07
    14
    Quote Originally Posted by rkmcswain
    The acad.unt file gives you a list of units that you can convert. It does not tell you such things like you can substitute 'sqft' for 'square feet' or 'in' for 'inch', etc. Oh well, it's not that big of a hassle to type out square feet or inch instead of using an abbreviation.
    Mert Garrison
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    I believe you can modify that file to read what you want it to read. If you want 'sqft' instead of 'square feet', this would be the file to make those changes. You may want to copy the desired lines and changing the copied lines, therefore keeping the previous units available as well.
    Earth
    9,804
    Quote Originally Posted by mert523
    Mert Garrison
    I guess I should have elaborated.
    When I said [Check out the ACAD.UNT file], I meant see if you can add your own abbreviations, so that I didn't have to do this.
    As it turns out, you CAN add your own, or modify the ones that are there.
  1. List of Abbreviations
    By cadkiller in forum CAD Management - General
    Last Post: 2006-08-16, 09:10 PM
  2. Abbreviations list
    By ashuler in forum Revit Architecture - General
    Last Post: 2006-02-21, 03:58 PM
  3. Diameter Ø & other symbols/abbreviations
    By markl.70662 in forum Revit Architecture - General
    Last Post: 2005-04-30, 06:54 AM
