Thread: Mass Properties-Mass
    2003-02
    2
    Default Mass Properties-Mass
    How do I change the Mass values in the massproperties command. It is returning 1lb per cu in.
    Thanks
    mjm_44
    2001-03
    13,499
    Default Re: Mass Properties-Mass
    Hi
    As far as I know, you can not within vanilla AutoCAD ( though something could be written in AutoLISP / VBA / etc to work round this limitation ).
    I believe AutoCAD uses a density of 1 with the _.MassProp command.
    I believe Inventor and_or Mechanical Desktop allow different densities to be set.
    Take a look at the following threads, hopefully they will give you one or two ideas...
    converting units
    AutoLISP routine to calculate the total weight of steel
    Have a good one, Mike
    2003-02
    2
    Thanks for the answer and the links
  1. Mass floors in conceptual mass family environment?
    By twaldock in forum Revit Architecture - General
    Last Post: 2010-11-15, 10:44 PM
  2. Mass Family - Mass Schedule - Missing Parameters
    By mmcdonald in forum Revit Architecture - Families
    Last Post: 2009-02-26, 05:19 PM
  3. Mass parameters in mass floor schedule
    By arqt49 in forum Revit Architecture - General
    Last Post: 2009-01-20, 05:10 PM
