Results 1 to 9 of 9
Thread: Bring to front Text over a Solid Hatch
    2004-10
    22
    Question Bring to front Text over a Solid Hatch
    Applying 'Bring to front' to text over a solid hatch only works in the current session.
    When the drawing is opened again (after having saved it properly), it has reverted to being under the hatch. Regen or Regenall does not work.
    It is a real pain having to go to every piece of text and re-set it.
    Any thoughts?
    For the time being, I am going to split the bounding frames, hatch and text onto seperate layers to help with applying 'bring to front' next time I open it, but I don't think that this should be neccessary; I am trying to keep the number of layers manageable - this is going to create another 12.
    Sincerely
    Patricia
    13,656
    Default Re: Bring to front Text over a Solid Hatch
    Hi Patricia
    Please note I have *moved* this thread from the ASK the BOD forum to this one...
    Thanks, Mike
    Forum Moderator
    13,656
    2004-10
    22
    Smile Re: Bring to front Text over a Solid Hatch
    Thanks, Mike
    Texttofront works a treat.
    2004-12
    80
    I know this thread is a bit old.. But I'm having a similar type issue.
    Using ACAD 2005. We have an MText box using true type fonts and this is located over a solid hatch. I am trying to print this and the whole thing shows up as solid. This happens even on our color printers. I sort of understand why this would happen on a black and white printer, but shouldn't it print correctly on the color plotter?
    Any thoughts?
    Earth
    9,805
    Quote Originally Posted by Shizzjr
    In your print driver, check the Merge Control option.
    "Lines Merge" may be the option you need.
    R.K. McSwain | CAD Panacea |
    2004-12
    80
    Thanks for the reply. That was the first option I checked too. I've been through just about every setting for the printer and I just can't get it to print correctly.
    I might just have to accept that it can't be done.
    I could stop if I wanted to sschwartz85916's Avatar
    2005-04
    Oakland County, Michigan
    424
    If this is a solid hatch, you can make a text mask with the background to be the same color as the solid hatch, type textmask, m for masktype, then s for solid, it prompts you then for a color to select.
    2004-08
    Iron Station, NC
    3,198
    have you tried using a dense dot hatch pattern instead of solid?
  1. Bring Viewports to Front
    Last Post: 2014-10-28, 09:51 PM
  2. Drafting Tool - Bring to Front
    By mmiles in forum Revit Architecture - General
    Last Post: 2008-12-16, 11:03 PM
  3. Many text and dimensions to bring to front?
    By pferreira in forum AutoCAD Tips & Tricks
    Last Post: 2006-06-30, 10:27 PM
  4. Bring to Front, foreward-backward
    By mmolina in forum Revit Architecture - General
    Last Post: 2005-06-03, 08:19 PM
  5. Bring to front/send to back??
    By Kelly@Laebon in forum Revit Architecture - General
    Last Post: 2004-04-30, 10:46 PM
