Thread: wall poche disappearing
    2005-05
    40
    Default wall poche disappearing
    in constructs our wall poche is disapearing when wall is copied from a node and placed onto another intersection/endpoint/midpoint etc. (this is not a wall typical wall error as have always seen) happens when placed on polyline, xref, reference point and can not be corrected etc. suggestions???? HELP!!!
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: wall poche disappearing
    Check to make sure the wall is at a zero elevation. I noticed this in a file the other day where the wall did not go down to a zero elevation & as soon as it was dropped it displayed fine. Another thing you could try is to change your cut plane height - that might allow the hatch to display.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2005-05
    40
    the elevation was at a negative. so that fixed it. what causes this to happen? is it user error? thanks again
    2002-09
    Madison, WI
    5,688
    Quote Originally Posted by willc
    Most likely. Are you using Project navigator. Someone may have assigned it to a wrong level, in which case it was drawn correct, just pushed to the wrong elevation.
  1. Wall Style for dashed poche
    By luke.stearns578139 in forum ACA General
    Last Post: 2012-11-21, 11:20 PM
  2. Wall Poche
    By eric.110455 in forum Revit Architecture - General
    Last Post: 2009-01-12, 04:44 PM
  3. Wall poche in plan but not section
    By lm.136504 in forum Revit Architecture - General
    Last Post: 2008-08-22, 10:15 AM
  4. Wall Poche
    By richelleharp in forum Revit Architecture - General
    Last Post: 2007-07-25, 05:11 PM
  5. Poche a wall
    By BrianE365 in forum AutoCAD General
    Last Post: 2006-05-08, 04:15 PM
