Results 1 to 10 of 19
Thread: Print Area - Margins appear smaller in one drawing file
    2001-11
    200
    Default Print Area - Margins appear smaller in one drawing file
    Hi
    I have a strange problem where the margins on the plotted drawings for one drawing only, happens on all layouts on this particular drawing, are smaller than previously plotted drawings. The drawing template is the same as a number of drawings which when printed shows a much wider margin to the paper edge.
    I have tried to check the properties of the printer and also the border of the drawing and all seem the same as other drawings which print the margin correctly.
    One strange thing is the when you click on zoom extents on the drawings which print correctly it zooms to the dotted line, the printable area line I gather, whereas the drawing where the margin is smaller zooms to the actual border of the drawing template.
    Dont know if this explains my problem very well but hopefully this is a problem which someone has come across before.
    Regards
    Neil
    2001-03
    13,499
    Default Re: Print Area - Margins appear smaller in one drawing file
    Quote Originally Posted by neilcheshire
    Hi
    Can you please post one "good" drawing file and the "bad" drawing file, so me can take a look at the issue / problem first-hand...
    My initial thought - Something ( eg Object of some kind ) or System Variable is causing the problem.
    Have a good one, Mike
    0,0,0 The Origin
    8,027
    Are you plotting to scale or to fit?
    Are you plotting Layout, Extents, Display, Window,?
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2001-11
    200
    John
    We are using extents and fit to paper on all drawings.
    Mike
    The drawings are 3Mb or so which I think is too big to send can I try anything else first.
    Regards
    Neil
    0,0,0 The Origin
    8,027
    John
    That makes it sound as if something is missing from the "bad" drawing that is present in all the others. Perhaps the good drawings have Points to control the limits or extents?
    John B
    2001-03
    13,499
    Hi
    How about doing a SaveAs on a "good" drawing file and the "bad" one; deleting / removing all! ModelSpace Objects; deleting all Layouts except one; then run the _.Purge command; place in ZIP file for further file size compression if required.
    Performing such a task I would have thought, would reduce file size down to an acceptable level for posting.
    2001-11
    200
    Mike
    Please find attached bad file. Good file to follow
    2001-03
    13,499
    Hi Neil
    No file was attached to above post, can you please take a look and try attaching again.
    Mike
    2001-11
    200
    Mike
    Here is a good file.
    Neil
    2001-11
    200
    Sorry Mike File was too big, lets try again.
  1. Print clipping within margins
    By mtc.139414 in forum AutoCAD LT - General
    Last Post: 2009-04-16, 08:01 AM
  2. how to make a much smaller file in 3d
    By jlizann in forum Revit Architecture - General
    Last Post: 2006-07-08, 03:46 AM
  3. Print Margins
    By janunson in forum Revit Architecture - General
    Last Post: 2005-09-28, 09:18 PM
  4. Titleblock margins don't print
    By pfrederico in forum Revit Architecture - General
    Last Post: 2005-07-02, 06:02 PM
  5. How To: Print an area of a drawing by "Window"
    By Scott Davis in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-09-24, 02:09 PM
