Thread: routine for insert block break line
    I could stop if I wanted to 09silverado's Avatar
    2005-12
    Connecticut
    484
    Default routine for insert block break line
    http://forums.augi.com/showthread.ph...3&page=3&pp=10
    page 1 shows what i'm trying to do.
    insert a block (either internal or external of current dwg i.e. block or wblock, be able to rotate it, edit it's attribute, then have the program break the line i inserted the block on based on a pl contained within the block.
    did you get that, lol? we have multiple blocks...
    ...it's a contour label block i made and i'm trying to reduce the insert, rotate, then break line etc.... follow me?
    i have no clue if vba is better for this or not, i do know that we don't like buttons..... so that may drive this. maybe c++?
    thank you!
    Thank you kindly
    Cad Committee Technical Adviser
    R14 - C3D 2012
    http://www.youtube.com/user/butzers03xtreme I drive a Silverado, its loud and i like it
    Administrator RobertB's Avatar
    2001-08
    Dallas TX USA
    5,825
    Default Re: routine for insert block break line
    Wipeouts, even with their issues, is far better in the long run than breaking the lines.
    2002-02
    Kansas
    482
    Quote Originally Posted by RobertB
    in place of wipeouts use 3dfaces and plot with line hide on
    Note:
    update to 2011
    I am using ADT 2007 08/06/2008
    PS. If you use any Code I post or Down Load Attachment I would like to know if it was helpful. So please post reply to this thread, on how you use the code or down load. Thank You
    2001-08
    Dallas TX USA
    5,825
    The problem with 3DFaces is that you need to draw stuff with elevation differences to be able to hide things, as opposed to using draw order.
    2002-02
    Kansas
    482
    yes but the elevation deferences is done in the block. just as the Wipeout is. but with Wipeout the draw order of the block need to the change if a line in move. where as with 3DFaces as long as the elevation of the line dose not change the block need not to be change.
    note: you can all so use region
    Note:
    update to 2011
  1. Insert block and break any line in its way
    By jgratton in forum AutoLISP
    Last Post: 2007-11-13, 03:53 PM
  2. insert block (all predefined) break line inserted on
    By 09silverado in forum AutoLISP
    Last Post: 2007-11-08, 03:46 PM
  3. Date Insert Block routine
    By b_v_mc in forum AutoLISP
    Last Post: 2006-05-17, 05:59 PM
  4. Block insert and explode lisp routine
    By rayski in forum AutoLISP
    Last Post: 2005-05-19, 01:21 PM
