Results 1 to 7 of 7
Thread: How to draw 3D in AutoCAD
    2006-01
    3
    Default How to draw 3D in AutoCAD
    hi, i am new to this and i really need help with how to making 3d drawings in autocad,
    1, how do i start making 3d
    2, if i have plan, elevations and all that how can i get a 3d out of them
    any help will be appreciated
    thank you
    VDC Manager Brian Myers's Avatar
    2003-02
    St Louis, Missouri
    1,808
    Default Re: How to draw 3D in AutoCAD
    Quote Originally Posted by bibema
    thank you
    While I could likely give you a bit more info than this, it's likely important I ask this question first as it might generate a more informed response from a person in a specific field: What type of drawing are you looking to do? Will it be Mechanical, Architectural, etc?
    From this answer we'll likely be able to give you a better response. The "simple" answer is that there is no simple way to do this, but there are some things you might be able to do depending on exactly what you are trying to accomplish.
    Brian Myers
    Virtual Design and Construction Manager | BIM Manager | Author
    LinkedIn Profile
    Super Moderator blads's Avatar
    2015-10
    out cycling somewhere... I wish...
    2,284
    thank you
    If I remember correctly from my old 3d AutoCAD days, if you have drawn the "plan" in a polyline, then that may be extuded to form your basis of the 3d model.
    However, the simplest way to give a 3-D representation while using only 2-D commands, is to create an Isometric drawing. This has been the usual way of doing things before CAD allowed true 3-D work to be done.
    This is only one way, there are countless others as many more imformed than I will help...
    Cheers @blads
    Mac Geek | Building Design Suite 2017 | Redstack Applications Engineer - Building Design | Autodesk Certified Professional
    I could stop if I wanted to de-co1's Avatar
    2005-07
    Jhb - ZA
    272
    The very basis from which to begin, is to learn to work with X, Y and Z axes... 3D Space. The type of industry you are working in will determine to a degree the manner in which you create your models, but no matter what type of industry it is for, it is important to be able to work within three dimensional space. Get your head around the basics of using 3D geometry (cylinders, boxes, spheres, cones, donuts), drawing using the 0,0,0 (X,Y,Z) annotation, the use of faces, extrusions, paths and planes, and creating compound geometry using addition, subtraction, and union (although I would suggest steering clear of this as much as possible if you intend exporting large models to MAX / VIZ as face and vertex counts increase drastically)
    In the end, it is all these and bit a more that you will be using, but once you have the basics down, you'll be able to pick up on the rest with practice.
    David
    "Artists to my mind are the real architects of change, and not the political legislators who implement change after the fact."
    William S Burroughs
    13,626
    Hi
    Try the links found in the following posts...
    RE: Learning 3D drawings in AutoCAD 2005
    RE: Looking for Rendering Advice
    Have a good one, Mike
    2003-11
    277
    thank you
    Hi bibema,you can learn how to create drawing in 3d,look at attach file.I hope this help you
    150700
    3,434
    Also, it looks like in February there will be at ATP course that might help you out. Check it out here
  1. excel data to draw line in autocad.
    By yonlih in forum VBA/COM Interop
    Last Post: 2013-11-30, 03:14 AM
  2. Replies: 0
    Last Post: 2011-11-16, 11:20 PM
  3. We can draw all this by AutoCAD
    By abd-513 in forum AutoCAD Gallery
    Last Post: 2007-10-19, 06:39 PM
  4. An easy way to draw a 3d roof in AutoCAD 2004...2007
    By Brogueira-CADptbr in forum AutoCAD Tips & Tricks
    Last Post: 2007-02-26, 03:47 AM
  5. Proper Way to Draw Arcs from a Survey in AutoCAD
    By stilesj in forum AutoCAD General
    Last Post: 2006-09-28, 11:30 AM
