Please tell me how to take OLE text & convert it to AutoCAD text.
Hi
Please note I have *moved* this thread from the AutoCAD Customization forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
Thanks, Mike
Forum Moderator
Hi
Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
ID: TS17736 - Pasting OLE objects as AutoCAD objects
Have a good one, Mike
Thanks Mike, I was not sure where this should be posted.
I did not state I problem very will. I received a DWG with OLE text in it. I need to explode it into "text" & rework it some. I did it once before, but have forgotten how I did it.
Never mind, I found one way.
Copy clip OLE
Goto: Edit
Goto: Special Paste
In dialog box pick :
(paste) & % PRODUCT Entities
then OK
Not if your dialog says % PRODUCT Entities instead of AutoCAD EntitiesOriginally Posted by Mike.Perry
See: http://support.autodesk.com/Getdoc.asp?ID=TS59829
R.K. McSwain | CAD Panacea |
