Results 1 to 7 of 7
Thread: Visibility Parameter Enhancement
    ACAD Wish List Administration
    2005-06
    1,920
    Default Visibility Parameter Enhancement
    Summary: The ability to add more than one visibility parameter to a dynamic block.
    Description: Dynamic Block Visibility Parameter Enhancements
    How Used: Specifically the Visibility parameter...Having Multiple Visibility parameters would enable us to make changes to different parts of the block...This would help out in the creation...If you have 4 different things that can be in 2 different places in the block, the single visibility Param gets quite long...My example would have 16 different selections when only one per side is needed.
    Feature Affinity: Blocks
    Submitted By: Ray Mendoza on December 29, 2005
    I could stop if I wanted to Ogre's Avatar
    2005-06
    In the end, Cauliflower is just albino Broccoli
    288
    Default Re: Visibility Parameter Enhancement
    The example I was thinking of is this...If you have a 2-gang wall box...There can only be 2 lighting controls inside that wall box...Well, if you have 4 different products that can go together, then you have 16 different combinations...If you had multiple visibility parameters, all you would need is one parameter for each control rather than one parameter that lists the 16 different combinations...
    150700
    3,434
    Thanks for the additional clarification; it always helps
    Professional Member walt.sparling's Avatar
    2009-04
    Tampa, FL
    13
    Great ad. If the visibility parameter(s) could be chose on insert like scale and rotation, that would be even slicker.
    Walt Sparling
    Electrical Designer, Otto Engineering, Inc.
    Professional Member
    AUGI Director
    www.functionsense.com
    Programming Moderator BlackBox's Avatar
    2009-11
    5,222
    Quote Originally Posted by Ogre View Post
    Have you tried simply adding your four, different dynamic blocks to a Group?
    Obviously, this changes nothing about native support for multiple parameters within a single BlockTableRecord, but just might suffice in the interim.
    Cheers
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    2015-12
    2,047
    There would need to be some method to handle visibility conflicts. Would each entity be limited to participation in only one visibility set? If not ie. each entity could belong to multiple visibility sets, how would it handle an entity which one visibility set indicates as hidden and another as visible?
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
    2009-11
    5,222
    Quote Originally Posted by dgorsman View Post
    1+... Methinks this be the reason for the single Visibility parameter limitation we currently benefit from.
  1. Add a new visibility parameter
    By Mac Demer in forum Dynamic Blocks - Technical
    Last Post: 2016-09-13, 12:48 AM
  2. Parameter Visibility
    Last Post: 2012-11-13, 02:03 PM
  3. Visibility Parameter
    By scherckas in forum Nordic - Revit Architecture
    Last Post: 2011-11-22, 02:21 PM
  4. Yes/No Visibility Parameter with Secondary Parameter Help
    By bpayne in forum Revit Architecture - General
    Last Post: 2011-06-15, 05:52 PM
  5. Family element visibility settings enhancement
    By ctc in forum Revit - R & D Lounge
    Last Post: 2008-05-08, 09:13 PM
