I am in the final stages of a FLW Prairie Look House and I have
had considerable problems with stacked wall joins and sweep joins.
I have extensively used stacked walls in this project. The joins
problems I am experiencing are with stacked walls of the same
parameters and type (brick veneer with a STO DRYVIT top). I have 3 sweeps
that will be made from STO DRYVIT: a sill, a band midway up the stucco,
and a freeze double band. On about 50 % of these wall joins one or
more of these problems arise: the plan view does not show a join,
the elevation does not exhibit join and the 3D view does not have
a join. The sweeps exhibit those same problems.
Any thoughts. I have spent way to much time, hours and hours and
hours and hours and I thought to take it to you guys and gals
for suggestions. Thanks for your help as always.
