We're having a weird problem over here where a certain linetype, when loaded, gets a "bad definition at line..." error. The linetype uses a shape file called "ARC" and works on some people's machines but not on others. All the support paths are there. We've even moved the support path to the top of the list so it can't bomb or be truncated. All other linetypes with special shapes from the same LIN file load and work fine except this one. We've copied the shapes into AutoCAD's support directory and still doesn't work. Everything in the LIN file is OK because we've been using this thing forever in AutoCAD and it works for some people. Here's the weird part. When you type "LOAD" and browse to the ARC shape file, it loads OK and you can insert the shape as much as you want into the file using the SHAPE command. Any thoughts as to why the linetype is getting a bad definition?
Oh yeah, we also tried to insert a file that had the linetype loaded as both a layer's linetype assignment and a line that was physically changed to the linetype but the linetype comes out as just dots.
