Thread: "Save As" dialog box instead of "Open"
    I could stop if I wanted to dmb.100468's Avatar
    2005-11
    Virginia
    222
    Default "Save As" dialog box instead of "Open"
    I have an ABS2006 user that is getting the "Save As" dialog box when using the Open command. Anyone else run into this? So far the only way to "fix" it is to restart ABS.
    2000-01
    Seattle WA USA
    5,859
    Default Re: "Save As" dialog box instead of "Open"
    I've never seen that behavior.
    2005-07
    40
    I haven't seen that before myself ... is it possible that the user has gone in a modified the CUI file accidentally? Are they using the original profile on first open and then changing to a new profile later? Have they removed the profile information from the shortcut link? That would seem to me like the only reason that a command would change like that.
  1. Windows " Open" , " Save " and " Save as" disappeared
    By chiab_gigi in forum AutoCAD Electrical - General
    Last Post: 2014-12-18, 10:28 PM
  2. Changing the "Line1", "Line2", etc headers in the Project description dialog box?
    By brynjolfur853743 in forum AutoCAD Electrical - General
    Last Post: 2013-04-15, 08:25 PM
  3. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  4. "Open" Dialog Box missing "Places"
    By jerry.105922 in forum AutoCAD Customization
    Last Post: 2007-12-13, 04:20 PM
  5. Replies: 8
    Last Post: 2007-04-04, 12:39 PM
