I have a customer who wants to have R be regen instead of redraw. I can not figure out how to assign a single letter with our the modifier... Am I missing something?
Hi
As far as I know ( which means nothing ) the Acad.pgp file is still in use with AutoCAD 2006 therefore are you modifying this file or attempting to do it via the CUI ?
Have a good one, Mike
Can't find a pgp anywhere... I think it is gone, or hidden? I have not used 2006 anywhere except my new job. I have not had a reason to do any costomisation as a AE. In my past life I would have killed smeone fro messing with my pgp or mnu files.
Scratch that just found it in a weird folder... C:Program FilesAutodeskAcadm 2007UserDataCacheSupportOriginally Posted by awarren
I am also running Mechanical too on this computer, that may be what through me...
The express tool "ALIASEDIT" will allow you to edit your PGP file without actually knowing where it is, or editing it in a text editor.
There is no reason, that I know of, that a single letter cannot be used as an alias...
Hi Andy
Please note I have *moved* this thread from the AutoCAD 2006 CUI Menus forum to this one...
Why? - This is not a CUI issue / problem.
Thanks, Mike
Forum Moderator
Sometimes the customization files get burried in the
C:\Documents and Settings\rhall\Application Data\Autodesk\Autodesk Mechanical Desktop 2006\R16.2\enu\support
folder-r-r-r-r-ssssss.
Drives me nuts!
Not a CUI issue? That is what I want is to do this in CUI? Not questioning your authority, just wandering?Originally Posted by Mike.Perry
HiOriginally Posted by awarren
As I originally stated above, quick keys that map to AutoCAD commands are controlled via the Acad.pgp file, therefore the CUI has nothing to do with this process ( as far as I know ).
FYI: One of my favorite ways of finding the pgp file is by typing this into the command line.
(findfile "acad.pgp")
