[ Moderator Mode = On ] Clearing up thread "Split" action. Original thread found here [ Moderator Mode = OFF ]
I have another question (and I'm sure it's on here, I just can't seem to find a thread to answer the question - if you can direct me to another thread that would be great, or if a mod would like to edit the question to become it's own thread that's fine too).
I created this dynamic block by editing a block within drawing 'A'. If I w-block the block from model space to it's own file 'B', when I insert it into drawing 'C' I have to explode it to get the dynamic properties to show. How do I go about setting this up so that when I insert the block I've made to another file I don't have to explode it once to get to the dynamic properties. I think the simplest answer is that next time I should start with a new drawing and during the bedit command select <current drawing> (correct?). In the meantime, how do I salvage the work I've done to this point so that I don't have to explode the block every time I insert to be able to use the dynamic properties (visibility state)? If it weren't so much work I'd start over, but I'm way to far into the block at this point - starting over would be a MAJOR time killer.
