Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: Remove $0$ and everything before from Layer names
    I could stop if I wanted to cadd4la's Avatar
    2001-12
    Newport Beach, CA
    399
    Question Remove $0$ and everything before from Layer names
    Hi everyone,
    Does someone know how to write a lisp or know where I can find the code, that will remove $0$ and everything before that from the layer name in the layer manager.
    From this - 532-IMP-BASE$0$area
    to this - area
    We are binding all the Civil, Architecture, & our base file to map a key map for the project.
    Kyle C.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Remove $0$ and everything before from Layer names
    When you BIND the xref, have you tried the INSERT option? I believe this would resolve the problem, unless you have already done the binding.
    2001-12
    Newport Beach, CA
    399
    Opie,
    I did use the insert option when I binded the xref's, thats why I got the $0$.
    but thanks for your input.
    Kyle C.
    Quote Originally Posted by Opie
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Quote Originally Posted by kylec_edg
    . . .I did use the insert option when I binded the xref's, thats why I got the $0$. . . .
    Nope,
    you can
    bind as bind
    and
    bind as insert
    : ) Happy computing !
    kennet
    2002-05
    1,707
    . . . From this - 532-IMP-BASE$0$area
    to this - area . . .
    This is a sticky task,
    if layer area do not exist, rename is easy to do,
    if layer area exist, objects must move from .....$0$area to layer area.
    : ) Happy Computing !
    kennet
    2001-12
    Newport Beach, CA
    399
    kennet,
    No new layers exist other then the layers that we added in our base file, because all I am doing is doing a save as of our base and binding the xref's.
    Kyle C.
    Quote Originally Posted by kennet.sjoberg
    kennet
    2002-01
    jUSt Here (a lot)
    9,105
    kennet,
    Kyle C.
    How many xrefs? If more than one xref contains the same layer names then the situation that kennet mentioned will occur.
    2001-12
    Newport Beach, CA
    399
    Opie,
    Now I have a problem, I don't think about that .
    I have about 26 xref's and 13 of them are from the architect and I know they have the same named layers in all of them.
    Any Ideas on how to get around this maybe when it reads the layer name it can add a "X" and a "number" that increases, I just looking to get the layer names to be smaller.
    bko_451-xf-1a1$0$ABVBLW to X1ABVBLW
    bko_451-xf-1b1$0$ABVBLW to X2ABVBLW
    etc.
    Kyle C.
    2002-05
    1,707
    . . .Now I have a problem. . .
    Yes you have,
    if there is block in the binded xref ( and of course there is ) you have problem in problem.
    and it is not only layers, it is textfons, linefonts, dimensionstyles. . . .
    Next time bind as insert ; )
    kennet
    All AUGI, all the time CAB2k's Avatar
    2016-01
    Brandon, Florida
    687
    Perhaps this will help.
    ;;;=======================[ LayerXrename.lsp ]=======================
    ;;; Author:  Charles Alan Butler
    ;;; Version:  1.0 jan. 10, 2006
    ;;; Purpose: Rename Bound xref layers  $0$ to X1-Layername
    ;;; Sub_Routines: -None
    (defun c:layerxrename (/ usercmd lnamelst laylst x newname prefix prefixcnt tmp)
      (vl-load-com)
      (setq usercmd (getvar "CMDECHO"))
      (setvar "CMDECHO" 0)
      (setq laylst (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
      (vlax-for x laylst
        (setq lnamelst (cons (list (vla-get-name x) x) lnamelst))
      (setq lnamelst (vl-sort lnamelst '(lambda (e1 e2) (< (car e1) (car e2)))))
      (setq prefix ""
            prefixcnt 0
      (foreach x lnamelst
        (if (wcmatch (car x) "*$*$*") ; rename the layer
          (progn
            (if (/= (setq tmp (substr (car x) 1 (vl-string-search "$" (car x)))) prefix)
              (setq prefixcnt (1+ prefixcnt)
                    prefix tmp)
            (setq newname (strcat "X" (itoa prefixcnt)  "-"
                                  (substr (car x) (+ 4 (vl-string-search "$0$" (car x))))
            (vl-catch-all-apply 'vla-put-name (list (cadr x) newname))
      (setvar "CMDECHO" usercmd)
      (princ)
    (prompt "\nXref Layer Rename removes $0$, Enter LayerXrename to run.")
    (princ)
  1. Replies: 11
    Last Post: 2009-02-27, 04:25 PM
  2. Replies: 6
    Last Post: 2007-05-30, 02:02 PM
  3. Replies: 2
    Last Post: 2007-01-09, 06:39 AM
  4. Change Layer names to other Layer names via a script?
    By tburke in forum AutoCAD Customization
    Last Post: 2006-12-04, 07:30 PM
  5. Replies: 12
    Last Post: 2006-10-06, 07:07 AM
