Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: Remove $0$ and everything before from Layer names
  1. #21
    13,656
    Default Re: Remove $0$ and everything before from Layer names
    Quote Originally Posted by johnh.101098
    so everytime i get a drawing from joe pie his layers have a routine that get translated through this routine from say...
    point-dumb to pnt-misc
    x-epcurb to x-curb
    x-ep to x-eop
    Hi
    Take a look at the AutoCAD command _.LayTrans
    Have a good one, Mike
  2. #22
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    layertranslater is great if both drawings have the same layer names... however mapping every time you translate sucks
    If you always do the same translation (i.e., someone regularly sends you drawings, and they always use the same layer names, and you always want them changed to your layer names, which also are always the same), then you can just save the mapping as a DWS file. Then just load the DWS file into Layer Translator and hit "Translate" - nice and painless.
  3. #23
    11
    is there a way to easily modify this lisp routine to find replace *_* to *-*
  4. #24
    2005-03
    From Kerala, Currently located at Bangalore, India
    95
    Question Re: Remove $0$ and everything before from Layer names
    Quote Originally Posted by CAB2k View Post
    Perhaps this will help.
    ;;;=======================[ LayerXrename.lsp ]=======================
    ;;; Author:  Charles Alan Butler
    ;;; Version:  1.0 jan. 10, 2006
    ;;; Purpose: Rename Bound xref layers  $0$ to X1-Layername
    ;;; Sub_Routines: -None
    (defun c:layerxrename (/ usercmd lnamelst laylst x newname prefix prefixcnt tmp)
      (vl-load-com)
      (setq usercmd (getvar "CMDECHO"))
      (setvar "CMDECHO" 0)
      (setq laylst (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
      (vlax-for x laylst
        (setq lnamelst (cons (list (vla-get-name x) x) lnamelst))
      (setq lnamelst (vl-sort lnamelst '(lambda (e1 e2) (< (car e1) (car e2)))))
      (setq prefix ""
            prefixcnt 0
      (foreach x lnamelst
        (if (wcmatch (car x) "*$*$*") ; rename the layer
          (progn
            (if (/= (setq tmp (substr (car x) 1 (vl-string-search "$" (car x)))) prefix)
              (setq prefixcnt (1+ prefixcnt)
                    prefix tmp)
            (setq newname (strcat "X" (itoa prefixcnt)  "-"
                                  (substr (car x) (+ 4 (vl-string-search "$0$" (car x))))
            (vl-catch-all-apply 'vla-put-name (list (cadr x) newname))
      (setvar "CMDECHO" usercmd)
      (princ)
    (prompt "\nXref Layer Rename removes $0$, Enter LayerXrename to run.")
    (princ)
    I am a beginner in Lisp. So please tolerate.....
    Can you please alter this code so as to rename the layers like
    GroundFloorPlan$0$A-ANNO-DIMS to A-ANNO-DIMS?
    But in that case it has to check;
    If
    the layer A-ANNO-DIMS already exists, and if so it has to merge GroundFloorPlan$0$A-ANNO-DIMS to A-ANNO-DIMS.
    Else
    Rename it to A-ANNO-DIMS
    Could you please help me out in this?
  5. #25
    2009-11
    5,719
    Quote Originally Posted by jhaagen View Post
    Perhaps, like so:
    (vl-load-com)
    (setq TestString "This_Is_a_Test")
    (while (vl-string-search "_" TestString)
      (setq TestString (vl-string-subst "-" "_" TestString)))
    Computer Specs:
  6. #26
    2008-02
    1,141
    One more way, but only works for single character replacement...
    ((lambda (str)
       (if (eq (type str) 'STR)
         (vl-list->string
           (mapcar (function (lambda (s)
                               (if (eq 95 s)
                                 45
                                 s
                   (vl-string->list str)
      "Pizza_And_Beer"
    The main purpose for showing this is that it's a lot faster than searching through a list with vl-string-search.
  7. #27
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Quote Originally Posted by harilalmn View Post
    If
    Else
    Here's mine, which does what you're referring to:
    (vl-load-com)
    (defun c:LayerClean (/ layers lo name badlayers name1 pos)
      (setvar "CLAYER" "0")
      (setq layers (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))
      (vlax-for lo layers
        (setq name (vla-get-Name lo))
        (cond
          ((and (vl-string-search "$" name) (not (vl-string-search "|" name)))
           (setq badlayers (cons name badlayers))
      (foreach name badlayers
        (setq name1 name
              lo (vla-Item layers name)
        (while (setq pos (vl-string-search "$" name1))
          (setq name1 (substr name1 (+ pos 2)))
        (cond
          ((tblsearch "LAYER" name1)
           (command "-LAYMRG" "_Name" name "" "_Name" name1 "_Yes")
          (t
           (vla-put-Name lo name1)
      (princ)
    Edit: As for the other question about "_" to "-", change the check for "$" to "_" - but also it would need a slightly different portion for calculating the new name. Instead of:
    You should have:
    (setq name1 (vl-list->string (subst (ascii "-") (ascii "_") (vl-string->list name))))
  8. #28
    2008-04
    25
    I love this place!
    I just ran into this exact problem!
    I'm adding this routine to my toolbars & Tool Palettes.
    Greg D.
  9. #29
    2001-03
    6
    This lisp rocks! Could you give me a hint how to modify it to pass through Autocad Architecture STYLES and rename those too?
    Thanks in advance.
    Steve in Alaska
  10. #30
    2015-11
    Jo'burg SA
    4,512
    You're all welcome.
    It's a bit more involved when it comes to styles. Unfortunately there no such command as DimStyleMerge, TextStyleMerge or LinetypeStyleMerge. The renaming portion might work normally, but with this scenario there's a high probability of 2 (or more) styles becoming one in the end - which would make rename only possible for the 1st style. As for ACA styles, I've not done much work in ACA as yet (more into Revit for that type of drawing work) - so I can't say with certainty it's going to be easy. The ACA (e.g. Wall) styles may just be saved as dictionaries (like the MLeader styles are) instead of tables (as the Layers, Linetypes, Text & Dimstyles are).
    Which means the lisp will have to step through the entire DWG (including all the blocks) and modify each entity to the required style, then purge the wrong style from the DWG. BTW, that's what the LayMrg command does with layers.
  1. Replies: 11
    Last Post: 2009-02-27, 04:25 PM
  2. Replies: 6
    Last Post: 2007-05-30, 02:02 PM
  3. Replies: 2
    Last Post: 2007-01-09, 06:39 AM
  4. Change Layer names to other Layer names via a script?
    By tburke in forum AutoCAD Customization
    Last Post: 2006-12-04, 07:30 PM
  5. Replies: 12
    Last Post: 2006-10-06, 07:07 AM
