Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: Remove $0$ and everything before from Layer names
  1. #31
    2015-08
    Istanbul, Turkey
    7
    Default Re: Remove $0$ and everything before from Layer names
    Hi there Irneb,
    This "layerclean" lisp seems to work %100 on layers, that it is really great; but it doesn't seem to effect on block names? Would it be possible to convert this into block renaming as well? But maybe renaming/merging two blocks the same, might cause some critical problems, indifferent from layer renaming? Maybe lisp might interact to ask whether or not to merge in case of conflict?
    Thx in advance and keep good work coming.
  2. #32
    2015-11
    Mountain View, Ca
    13
    Can someone please post the completed lisp? I'm way too rusty to complete this, and I sooo need this right now.
  3. #33
    2015-11
    Mountain View, Ca
    13
    Dude! This is awesome! I just used the SETBYLAYER command first to take care of "improper" blocks and it works fine. Thanks!
  4. #34
    2011-04
    5
    Quote Originally Posted by cadd4la View Post
    Hi everyone,
    Does someone know how to write a lisp or know where I can find the code, that will remove $0$ and everything before that from the layer name in the layer manager.
    From this - 532-IMP-BASE$0$area
    to this - area
    We are binding all the Civil, Architecture, & our base file to map a key map for the project.
    Kyle C.
    Dear Kyle
    I have a modified lisp routine to rename not only layers but blocks, styles, linetypes etc. This routine will rename nested names also e.f. 501Site$0$xsite$0$XR$0$PLAN to PLAN
    Just save the file and load and run command rnm
    ;; Routine to rename layers, block etc with binded $0$ names By Shashikant 27 Nov 2018
    (defun c:rnm()
    (a:rnm "LAYER")
    (a:rnm "BLOCK")
    (a:rnm "STYLE")
    (a:rnm "LTYPE")
    (a:rnm "DIMSTYLE")
    (defun a:rnm (ob / LYRDXF NEWLAYNAME NEWLAYNAME-TEMP NUM OLDLAYNAME tlay)
     (while (setq LYRDXF (tblnext ob (not LYRDXF)))
      (if (wcmatch (setq OLDLAYNAME (cdr (assoc 2 LYRDXF))) "*$0$*")
       (progn
        (setq tlay OLDLAYNAME)
        (while (vl-string-search "$0$" tlay)
               (setq NUM (+ (vl-string-search "$0$" tlay) 4)
                            NEWLAYNAME (substr tlay NUM)
               (setq tlay NEWLAYNAME)
        (if (= (tblsearch ob NEWLAYNAME) nil)
         (command ".rename" ob OLDLAYNAME NEWLAYNAME)
         (progn
          (setq CNT 1)
          (while (tblsearch ob (setq NEWLAYNAME-TEMP (strcat NEWLAYNAME "-" (itoa CNT))))
           (setq CNT (1+ CNT))
          (command ".rename" ob OLDLAYNAME NEWLAYNAME-TEMP)
     (princ)
    This is a very compact routine which will help
    Shashikant
  5. #35
    2019-08
    Quote Originally Posted by Shashikant View Post
    Dear Kyle
    (defun c:rnm()
    (a:rnm "LAYER")
    (a:rnm "BLOCK")
    (a:rnm "STYLE")
    (a:rnm "LTYPE")
    (a:rnm "DIMSTYLE")
       (progn
         (progn
          (setq CNT 1)
           (setq CNT (1+ CNT))
     (princ)
    Shashikant
    This Tool is awesome!! Thank you!
    Is it possible to avoid the counter and merge all similar objects?
  6. #36
    2006-04
    466
    You can add replace or remove prefixes with this
    (DEFUN C:RLP ()
     (PROMPT "\n*REPLACE LAYER PREFIX* ")
     (SETQ LTSRL 1)
     (SETQ LPRE (GETSTRING "\nEnter existing layer prefix<none>: "))
     (SETQ NLPRE (GETSTRING "\nEnter new layer prefix<none>: "))
     (SETQ LP 1)
     (WHILE LP
      (SETQ LTS (TBLNEXT "LAYER" LTSRL))
      (SETQ LTSRL NIL)
      (IF (/= LTS NIL)
       (PROGN
        (SETQ LTST (CDR (ASSOC 2 LTS)))
        (SETQ LTSTL (STRLEN LTST))
        (SETQ CP 1)
        (SETQ LP2 1)
        (WHILE LP2
         (SETQ LS (SUBSTR LTST 1 CP))
         (SETQ CP (+ CP 1))
         (IF (AND (= LPRE "") (/= LTST "0"))
          (PROGN
           (SETQ NLN (STRCAT NLPRE LTST))
           (COMMAND "RENAME" "LA" LTST NLN)
           (SETQ LP2 NIL)
         ));END PROGN/IF LS
         (IF (AND (= LS LPRE) (/= LTST "0"))
          (PROGN
           (SETQ NLN (STRCAT NLPRE (SUBSTR LTST CP)))
           (SETQ LP2 NIL)
         ));END PROGN/IF LS
         (IF (> CP LTSTL) (SETQ LP2 NIL))
        );END LP2
      ));END PROGN/IF LTS
      (IF (= LTS NIL) (SETQ LP NIL))
     );END LP
     (PRINC)
    );END RLP
  1. Replies: 11
    Last Post: 2009-02-27, 04:25 PM
  2. Replies: 6
    Last Post: 2007-05-30, 02:02 PM
  3. Replies: 2
    Last Post: 2007-01-09, 06:39 AM
  4. Change Layer names to other Layer names via a script?
    By tburke in forum AutoCAD Customization
    Last Post: 2006-12-04, 07:30 PM
  5. Replies: 12
    Last Post: 2006-10-06, 07:07 AM
