I have a wall type say 70_timber_Gboard_both sides, and in the structure of the model it had been entered as 69mm for the structure thickness. In dimensioning i had realized i needed this to be actually be 70mm. Now, the issue came from the type of wall was in multiple groups(group names TH1, TH2, TH3 and so on). And these walls had their positions constrained. So when editing the properties of the wall, changed the 69 to 70. Ok. Ok. this caused an error, constraints of the walls were not satisfied (fine), removed constraints. Error:edit is only allowed in edit group mode. Clicked edit group for group TH1, opened for editing repeated structure thickness change, and had to remove constraints (fine), but new error as cannot edit TH2 group!! unless in edit group mode. So cyclical error. repeated with TH2 but same deal, cannot edit TH1 unless in edit group mode. (I also tried selecting all the instances of the walls in the groups, and changing them to a different wall type but this also doesn't work) So, my solution was just to remove the walls of that type form the model group, change them in each case and then add them back to the group. Is there a way around this? I'd like to be able to just change the value, whatever it may be and it update to all the different groups. Help is alway appreciated. Chris.
