Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Ultra Lightweight 3D Models.
    2002-02
    St. Louis, MO
    4,688
    Default
    Here's an example of a toilet that acts 3D but is all 2D. This solves the problems of linework not masking textures of distant planes.
    This family consists of 3 detail components - plan, front side. Solid fills are used for all of the objects.
    These are then compiled into a 3D family. To get the object to project and cut correctly, two rectangles of model lines are constructed which define the imaginary model extents.
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Default Re: Ultra Lightweight 3D Models.
    Aaron, Good work fella.
    I have done a couple of these but had not thought of the model line rectangles.
    Pete
    2002-02
    St. Louis, MO
    4,688
    ..if you really want to be a modeling miser - you just need only a X-Y and Z line to define the extents. Save yourself 5 lines.
    Aaron Rumple, AIA
    2003-11
    37
    Aaron,
    I try your file and work nice but when I try making one from a new family template the filled region don't masking the information from distant planes. What kind of special operation you do?
    Regards,
    Ricardo
    2002-02
    St. Louis, MO
    4,688
    My filled regions are not filled regions in the family, but nested detail componets within the family.
    Aaron Rumple, AIA
    2003-11
    37
    Aaron,
    I create my filled regions on the detail component and then insert the detail component in the new temlate file but the filled region doen't work. I don't know what kind of change you made in the template file but if I use your file the filled region work but if I use one new template file the filled region doesn't work.
    Regards,
    Ricardo Granja
    I could stop if I wanted to rhys's Avatar
    2003-05
    Cotswolds, UK
    433
    Excellent now whos going to do a complete set of Armitage Shanks or Twfords fittings!!!
    2004-04
    Brisbane, Queensland, Australia
    47
    Hello,
    Lightweight 3D pans, basins, in wall cisterns etc. are what I am looking for. They need to be like this to keep file size under control, as there are a lot of fittings
    Aaron, your concept is great, but I am using R6.0, so no joy with your file.
    Does anyone have any of the above happenning in R6.0?
    mark_a
    100 Club dazza1639's Avatar
    2004-03
    Manchester UK
    121
    Quote Originally Posted by rhys
    Heres the twyfords entice/view toilet & sink just to get us started
    2004-04
    47
    Thanks dazza,
    However this project is release 6.0, so no joy for me here.
    I am working on this myself, and have got the pan and in wall cistern pretty close. File size is good too at 125k. I am using extrusions to create the three views. Have a few hiccups with pans moving in plan when I edit from the existing pan family to this one, but this a minor issue I hope to resolve.
    mark_a
  1. Ultra Large Renderings
    By spyguy0045 in forum Revit - Rendering
    Last Post: 2009-01-06, 09:12 PM
  2. Lightweight lights, still looking
    By Gordon.Price in forum Revit Architecture - Families
    Last Post: 2007-01-25, 01:22 AM
  3. Ultra Lightweight 3D Families
    By iru69 in forum Revit Architecture - Families
    Last Post: 2005-06-09, 12:22 AM
  4. Lightweight 2D Sanitaryware
    By Damo in forum Revit Architecture - Families
    Last Post: 2004-11-18, 09:10 AM
