Thread: Parsing Error in opening DWF File
    Member sanjay_yallure's Avatar
    2004-08
    India, Ahmedabad
    10
    Default Parsing Error in opening DWF File
    Hi
    I am facing problem in opening a DWF file created rather published from Autodesk Inventor Professional 10.0.
    Parsing error appears when tried to open the published DWF file.
    Error window is attached for reference.
    Regards,
    Sanjay Yallure
    2001-03
    13,499
    Default Re: Parsing Error in opening DWF File
    Quote Originally Posted by sanjay_yallure
    Sanjay Yallure
    < Personal contact information removed. >
    Hi Sanjay
    I personally would recommend that you edit your above post and remove your personal contact number (unless you are 100% happy about giving out such information publicly).
    You might also want to review "Forum Security" which can be found in the AUGI Forum Guidelines.
    Thanks, Mike
    Forum Moderator
  1. Error when opening a .dxf file...
    By terynl in forum ACA General
    Last Post: 2009-08-04, 12:55 PM
  2. Error While opening DWF file
    By satish in forum Design Review - General
    Last Post: 2009-03-02, 11:38 AM
  3. Replies: 3
    Last Post: 2008-07-28, 07:31 AM
  4. Error When Opening a file???
    By KELLI in forum Revit Architecture - General
    Last Post: 2007-10-04, 02:42 PM
  5. Error when opening file
    By pogibob in forum Revit Architecture - General
    Last Post: 2007-03-30, 06:30 PM
