Thread: ABS clash detection?
    2005-12
    5
    Default ABS clash detection?
    Can ABS run clash detection tests? If yes, what kind of reports does it generate?
    thanks,
    pjr
    2000-01
    Seattle WA USA
    5,859
    Default Re: ABS clash detection?
    It won't create a "report", AFAIK, but you can turn collision detection on and visually look for collisions.
    2006-01
    3
    hey peter
    the ABS Tools pull down menu has a clash reporter tool that you can use. i already tested it it generates a schedule table that has all the capabilities of any schedule table. ie you can use the show of the schedule table and it takes you automatically to the location of the clash
    you can also find the tool in the content browser
    tell me if this helps, i might be able to send you a more detailed procedure by mail
    2000-01
    Seattle WA USA
    5,859
    Thanks for that info. <sigh> There is soooo much to this program.
    2004-11
    Tri-Cities Washington
    20
    Does the Clash only work against BS entities, or can you run it against other entities like lines, solids... etc.?
  1. 2014: Beams for Clash detection
    By DAVE_FLETCHER_85520352 in forum Revit MEP - General
    Last Post: 2014-01-28, 07:41 PM
  2. Clash Detection Viewpoints
    By Revit for Breakfast in forum NavisWorks - General
    Last Post: 2011-12-20, 05:24 PM
  3. Clash Detection
    By brian.elbe in forum NavisWorks - General
    Last Post: 2010-09-28, 08:45 PM
  4. What is clash detection?
    By volker.joseph in forum NavisWorks - General
    Last Post: 2009-05-19, 02:36 PM
  5. clash detection?
    By peter.rumpf in forum Revit Architecture - General
    Last Post: 2006-01-18, 05:07 PM
