Thread: Render solution needed
    I could stop if I wanted to Cathy Hadley's Avatar
    2003-05
    San Diego
    222
    Default
    I am looking for a solution to the age old problem... too many trees.
    I just bought a new system, 2 gigs ram... nvidia ... blah blah blah...
    I still can't render my site. I am sure now that it is totally due to the number or accurender trees. There is a small orchard ... and a large permieter of Eucalyptus trees..
    Earlier someone suggested RPC trees... however I see no Eucalyptus ... Am I missing something? Does anyone know of any?
    Its very important to show the trees in the rendering as we are trying to get the point across to the planning powers that be that we are well *nestled* ...
    Any suggestions would be helpful...
    Thanks.
    CZH
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    Default Re: Render solution needed
    If you have access to photoshop or some other image editor, do 2 renderings, one with just the landscape, and one with the building(maybe a few trees around it for shadows, then merge the 2 images in photoshop.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
    I could stop if I wanted to robmorfin's Avatar
    2003-10
    Solana Beach, CA
    200
    cathy,
    you can create your own RPC with RPC creator from Archivision.com, first render your Accurender Eucalyptus in Revit in a view side oriented, then save that image as jpg, edit it in your paintshop pro, crop it, create an alfa image of it and then use them with the rpc creator (free), it will be a flat rpc, you can make a 3d rpc (not movable) in accurender for autocad (single images render, 360 frames, circle path around the object), but not in accurender for revit, also in MAX, VIZ, Maya, etc, etc.
    Please share afterwards.
    2003-05
    5,153
    Can you use a background photo of the existing site to pick up the majority of trees, then just place some in the foreground ?
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    2003-05
    San Diego
    222
    Thanks guys.. good sugestions all..
    I was leaning toward the existing site photo method myself... but I want to look through the trees at the new residence... Sounds lke it time to get my photoshop guru involved..
    Rob - Thanks I'll see what I can do with that RPC creator. And keep you posted.
    CZH
  1. Network render with the Scanline render engine
    By Steve_Bennett in forum DV - Tips & Tricks
    Last Post: 2012-04-19, 03:09 AM
  2. Render Revit Model with new Twilight Render Engine
    By FletchMT in forum Revit - Rendering
    Last Post: 2009-09-18, 07:48 PM
  3. render model and cant see it in the render window
    By sherflor in forum ACA General
    Last Post: 2009-07-17, 11:19 PM
  4. Replies: 1
    Last Post: 2008-09-18, 01:15 PM
