Thread: Dimensions with centerlines
    2004-06
    Memphis TN area
    6,701
    Default Dimensions with centerlines
    If you have a linear dimension type defined with a centerline pattern, what exactly controls whether or not the extension line is a centerline or not? There are some families that have a ref. plane at the center, but when I dimension to it, I do not get a centerline. Other families seem to put a centerline where I don't want it when I dimension to the edge of it or something. Any ideas?
    AERC, PLLC
    Hernando, Mississippi
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,532
    Default Re: Dimensions with centerlines
    Open the family and go into the properties of a reference plane. It can be defined as "center - elevation", "center - left/right", or "center - front/back". If it's defined as any of these it will get a centerline mark, otherwise it will not. At least that's my understanding. And you can only have one of each.
    Steve
  1. Automatic Centerlines
    By nick.kuzmik in forum Inventor - General
    Last Post: 2009-11-03, 05:24 PM
  2. Centerlines
    By robotgrass in forum AutoCAD General
    Last Post: 2008-09-21, 07:10 PM
  3. Applying Centerlines
    By rgarthe in forum Inventor - General
    Last Post: 2006-06-01, 01:18 AM
  4. Window Centerlines
    By philipnoland in forum Revit Architecture - General
    Last Post: 2005-10-14, 11:44 PM
