HCSL
1. Check out the View Range under view properties. For and explanation of the terms click on the HELP button.
2. Plan regions allow a different view range than the primary one set for the rest of the view. If you use transom windows alot you can also modify the family with an invisible line that would be intersected by the cut plane so it shows up in any plan view. Third alternative for this one is to use the linework tool and just draw the transom window locations in as dashed lines over.
