Thread: Top of roof missing in Section View
    2003-12
    Southern Ontario
    58
    Default
    When I do a section view the view only shows 1/2 of the roof. The top is missing.
    Also my east elevation is showing a cross section although the elevation arrow is 50 feet or so away from the exterior wall.
    Autodesk Revit Client Support Manager slb's Avatar
    2003-07
    Waltham, MA
    107
    Default Re: Top of roof missing in Section View
    Section and elevation views have both "cut planes" and the potential for "crop boundaries". The crop boundary can be active even if it is not visible and may be cutting off the top of your roof. Check the properties of the section view to see if crop region is on, but is, perhaps, not visible. If so, make it visible and adjust it appropriately, or turn it off completely.
    Elevation cut planes, unlike section cut planes, do not have to conincide with the elevation symbol. Take a look at the image provided. Although the elevation tag is well outside the model, the blue, cut plane for the elevation is inside the structure, effectively cutting the geometry in the resulting view.
    2003-12
    Southern Ontario
    58
    Thanks, On track now.
  1. Level missing in section view
    By Design Apparatus in forum Revit Architecture - General
    Last Post: 2011-09-15, 08:54 AM
  2. Pavement structure missing from Section view
    By j.uddin in forum AutoCAD Civil 3D - Sections
    Last Post: 2011-08-18, 03:59 PM
  3. mep section view/items missing
    By corr-what in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-02-23, 05:34 PM
  4. Section View with missing objects at certain height!
    By supaflyrawk in forum Revit Architecture - General
    Last Post: 2009-03-05, 02:28 AM
  5. Section View Depth Missing
    By Dave F. in forum Revit Architecture - General
    Last Post: 2008-11-20, 03:26 AM
