Hi,
Using Inventor Professional 10.0. When published a i-Part to content center. I'm not able to use it as i-Part. Can still use it as i-part as well.
Thanking you in advance
Regards,
Sanjay Yallure
Hi,
Regards,
Sanjay Yallure
hi i am nilesh from pune
I am facing the same problem as u said published i part i am not able to use it as i part from content center .
have u found solution to this?
will u plz share with me?
be cause i confused whethere i was wrong in publishing i part to content centre . u can mail me on nileshsatpute@yahoo.co.in
waiting for ur reply .
Yes, you cannot use it as an iPart since it is already published in the Content Center
however, you can add to the present parameters available
for example, you made an iPart of a M4x0.7 screw with varying lengths
what you can do is to add rows to the table
